[mapguide-users] initial displacement of map content
stoff
mail at effing.org
Sun Aug 2 06:24:13 EDT 2009
Hi Chris,
great job! That was exactly the problem ... if I activate the
propertyctrl, then the displacement does not occur anymore ...
I use mapguide enterprise 2009 ... Do you have an idea how to
find the fix? 'Cause I do not need the property panel on the
weblayout for the "web-dummys" ... cause there will be no
selection features ...
Thanks a lot,
Stoff
Chris Claydon wrote:
> This sounds like a defect that I thought had been fixed a long time
> ago. Which version of the MapGuide web tier are you using?
> Also, do you have the property panel disabled? I think that was the
> case when I last saw this issue.
> Sent from my iPhone
> On 2009-08-01, at 4:01 PM, "stoff" <mail at effing.org> wrote:
>> Hi,
>> I have a displacement of the map within the Ajax-Viewer (a white gap
>> at the
>> top of
>> the map). It happens on initial map visualization and disappears
>> when the
>> splitter
>> between layerctrl and mapframe is moved ...
>> http://n2.nabble.com/file/n3370781/versatz.jpg
>> Any hints are welcome ...
>> Best regards,
>> Stoff
>> View this message in context:
>> http://n2.nabble.com/initial-displacement-of-map-content-tp3370781p3370781.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/initial-displacement-of-map-content-tp3370781p3372229.html
