[mapguide-users] Unable load PostGisProvider on Ubuntu 8.04
    Zac Spitzer
    zac.spitzer at gmail.com
    Mon Aug  3 05:09:29 EDT 2009
that an oracle client error,
a quick google provided found that answer
http://www.google.com.au/search?q=CLNT_8_UNABLE_TO_LOAD_LIBRARY+fdo
try either installing the oracle instant client or remove the oracle
fdo provider
from your providers.xml
z
On Mon, Aug 3, 2009 at 6:53 PM, Takashige<takashige.nakagawa at gmail.com> wrote:
> Hi all,
> I'm using Mapguide Opensource 2.0.2 on Ubuntu 8.04 Server and it's running
> fine.
> But I get "CLNT_8_UNABLE_TO_LOAD_LIBRARY" error when I try to use
> PostGisProvider (ver3.3.1).
> PostgreSQL + PostGis seems running OK because I can create and refer to
> geospatial-tables on my server.
> PostGis Provider is built with no issue. No depenancies for the fdo provider
> are missing.
> But when I run the Mapagent's GetProviderCapabilities, it returns the error
> above.
> Do I have to do any spacial configuration or something to connect to
> PostGis?
> My PostgreSQL is version 8.3.7.
> Thanks.
> Takashige
> View this message in context: http://n2.nabble.com/Unable-load-PostGisProvider-on-Ubuntu-8.04-tp3376565p3376565.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
