[mapguide-users] google mgp
GordonL
gordon.luckett at arrowgeomatics.com
Fri Aug 7 09:21:07 EDT 2009
Yes, I loaded it with mg2010. The key to this package really is just
ensuring you have a map with the Sperical Mercator projection:
<CoordinateSystem>PROJCS["Popular Visualisation CRS / Mercator",
GEOGCS["Popular Visualisation CRS", DATUM["Popular Visualisation Datum",
SPHEROID["Popular Visualisation Sphere", 6378137, 0,
AUTHORITY["EPSG",7059]], TOWGS84[0, 0, 0, 0, 0, 0, 0],
AUTHORITY["EPSG",6055]], PRIMEM["Greenwich", 0, AUTHORITY["EPSG", "8901"]],
UNIT["degree", 0.0174532925199433, AUTHORITY["EPSG", "9102"]], AXIS["E",
EAST], AXIS["N", NORTH], AUTHORITY["EPSG",4055]], PROJECTION["Mercator"],
PARAMETER["False_Easting", 0], PARAMETER["False_Northing", 0],
PARAMETER["Central_Meridian", 0], PARAMETER["Latitude_of_origin", 0],
UNIT["metre", 1, AUTHORITY["EPSG", "9001"]], AXIS["East", EAST],
AXIS["North", NORTH], AUTHORITY["EPSG",3785]]</CoordinateSystem>
regards
gordon
Jackie Ng wrote:
> LayerDefinition-1.3.0.xsd does not exist in MapGuide 2.0.x, it was
> introduced in 2.1
> So that package can only be loaded on MGE2010 or MGOS 2.1
> - Jackie
> Ed Jobe wrote:
>> Gordon
>> The package failed to load with the following error.
>>> The specified schema file is not found: C:\Program
>>> Files\MapGuideOpenSource2.0\Server\Schema\LayerDefinition-1.3.0.xsd
>>> File:
>>> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\XmlSchemaResolver.cpp
>>> Line: 118
View this message in context: http://n2.nabble.com/google-mgp-tp3393692p3404315.html
