[mapguide-users] mysql data connection error
Jackie Ng jumpinjackie at gmail.com
Fri Aug 7 11:59:24 EDT 2009
You need to either copy libmysql.dll into MapGuide's FDO directory or make
sure that dll exists in a directory that is part of your PATH environment
variable.
- Jackie
chrismvn wrote:
> i want to display data from a mysql databse in my browser using mapguide
> and maestro. i am trying to create a dataconnection to a mysql database
> but i have the error below. i am a beginner in mapguide. should i
> reinstall mapguide ?
> The remote server returned an error: (559) MgFdoException.:
> An exception occurred in FDO component.
> The runtime was not found (module LIBMYSQL.dll). Please verify your mysql
> client component installation.
> Exception occurred in method MgFdoConnectionManager.Open at line 858 in
> file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\common\manager\FdoConnectionManager.cpp
View this message in context: http://n2.nabble.com/mysql-data-connection-error-tp3404937p3405198.html
