[mapguide-users] Change order of fields displayed in properties
pane?
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Fri Aug 14 09:12:13 EDT 2009
The preview release, since two or three preview releases ago.
I don't think the join stuff can influence the order.
If you still get unsaved stuff in the preview, be sure to report it, so
I can fix it before the next major release.
Regards, Kenneth Skovhede, GEOGRAF A/S
Jo Cook skrev:
> It does? Which version? I am currently using the stable version, which is
> playing hell with the properties- if I change the display name (and save) it
> sets it back on reload, and none of my changes seem to persist to the
> viewer. Come to think of it, I'm using a joined layer. Is this likely to be
> compounding the issue?
> Thanks
> Jo
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> Maestro supports ordering of the properties, but perhaps the viewer
>> sorts them afterwards.
>> James Card skrev:
>>> On Thu, 13 Aug 2009 07:50:21 -0700, Jo Cook <j.cook at oxfordarch.co.uk>
>>> wrote:
>>>> Is it possible to specify the order in which fields are displayed in
>>>> the properties pane? Currently it seems to display them in
>>>> alphabetical order, rather than the order in which they appear in the
>>>> data source. The only way I can think of getting round it at the
>>>> moment is to number all of the properties, which will look a bit
>>>> strange...
>>> I don't know of any way to specify the sort order. The workaround we
>>> use, rather than numbering the property names, is to insert leading
>>> spaces in the property names. This causes them to be sorted according
>>> to number of leading spaces, but since HTML collapses whitespace to a
>>> single space the display still looks looks good.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090814/1e496438/attachment.html
