[mapguide-users] Change order of fields displayed in properties pane?
Dave Wilson dave.wilson at autodesk.com
Fri Aug 14 10:33:53 EDT 2009
As far as the AJAX Viewer is concerned the order will still be alphabetical as far as I know. Realistically an enhancement that lets the user drag the fields in the layer editor into an order should actually build the query options with the properties in that order. When they are read from the query the order should stay the same.
That's probably and RFC.
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth Skovhede, GEOGRAF A/S
Sent: Friday, August 14, 2009 7:12 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Change order of fields displayed in properties pane?
The preview release, since two or three preview releases ago.
I don't think the join stuff can influence the order.
If you still get unsaved stuff in the preview, be sure to report it, so I can fix it before the next major release.
Regards, Kenneth Skovhede, GEOGRAF A/S
Jo Cook skrev:
It does? Which version? I am currently using the stable version, which is
playing hell with the properties- if I change the display name (and save) it
sets it back on reload, and none of my changes seem to persist to the
viewer. Come to think of it, I'm using a joined layer. Is this likely to be
compounding the issue?
Thanks
Jo
Kenneth Skovhede, GEOGRAF A/S wrote:
Maestro supports ordering of the properties, but perhaps the viewer
sorts them afterwards.
James Card skrev:
On Thu, 13 Aug 2009 07:50:21 -0700, Jo Cook <j.cook at oxfordarch.co.uk><mailto:j.cook at oxfordarch.co.uk>
wrote:
Is it possible to specify the order in which fields are displayed in
the properties pane? Currently it seems to display them in
alphabetical order, rather than the order in which they appear in the
data source. The only way I can think of getting round it at the
moment is to number all of the properties, which will look a bit
strange...
I don't know of any way to specify the sort order. The workaround we
use, rather than numbering the property names, is to insert leading
spaces in the property names. This causes them to be sorted according
to number of leading spaces, but since HTML collapses whitespace to a
single space the display still looks looks good.
mapguide-users mailing list
mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090814/7f024217/attachment.html
