[mapguide-users] Change order of fields displayed in properties pane?
Andrew DeMerchant andrew.demerchant at gemtec.ca
Fri Aug 14 10:42:22 EDT 2009
Here's a post from James Card to this group from 2006 that's got a
workaround:
"The other thing I've done is add leading SPACE charcters to the display
name for the field in the Layer setup. Since HTML collapses multiple
spaces into a single space this allows me to specify exactly which order
they sort in. "
Andrew
On 8/14/2009 11:33 AM, Dave Wilson wrote:
> As far as the AJAX Viewer is concerned the order will still be
> alphabetical as far as I know. Realistically an enhancement that lets
> the user drag the fields in the layer editor into an order should
> actually build the query options with the properties in that order.
> When they are read from the query the order should stay the same.
> That's probably and RFC.
> Dave
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Kenneth
> Skovhede, GEOGRAF A/S
> *Sent:* Friday, August 14, 2009 7:12 AM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] Change order of fields displayed in
> properties pane?
> The preview release, since two or three preview releases ago.
> I don't think the join stuff can influence the order.
> If you still get unsaved stuff in the preview, be sure to report it,
> so I can fix it before the next major release.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Jo Cook skrev:
> It does? Which version? I am currently using the stable version, which is
> playing hell with the properties- if I change the display name (and save) it
> sets it back on reload, and none of my changes seem to persist to the
> viewer. Come to think of it, I'm using a joined layer. Is this likely to be
> compounding the issue?
> Thanks
> Jo
> Kenneth Skovhede, GEOGRAF A/S wrote:
>     Maestro supports ordering of the properties, but perhaps the viewer
>     sorts them afterwards.
>     James Card skrev:
>         On Thu, 13 Aug 2009 07:50:21 -0700, Jo Cook<j.cook at oxfordarch.co.uk>  <mailto:j.cook at oxfordarch.co.uk>
>         wrote:
>             Is it possible to specify the order in which fields are displayed in
>             the properties pane? Currently it seems to display them in
>             alphabetical order, rather than the order in which they appear in the
>             data source. The only way I can think of getting round it at the
>             moment is to number all of the properties, which will look a bit
>             strange...
>         I don't know of any way to specify the sort order. The workaround we
>         use, rather than numbering the property names, is to insert leading
>         spaces in the property names. This causes them to be sorted according
>         to number of leading spaces, but since HTML collapses whitespace to a
>         single space the display still looks looks good.
>     _______________________________________________
>     mapguide-users mailing list
>     mapguide-users at lists.osgeo.org  <mailto:mapguide-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/mapguide-users
	*Andrew DeMerchant*
*Computer Technologist*
ph.1-877-2GEMTEC x.163
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
Fredericton, NB, Canada
E3C 2E6
This e-mail message (including attachments, if any) is confidential and may be privileged. Any unauthorized distribution or disclosure is prohibited.  Disclosure to anyone other than the intended recipient does not constitute waiver of privilege.  If you have received this e-mail in error, please notify us and delete it and any attachments from your computer system and records.
Ce courriel (y compris  les pièces jointes) est confidentiel et peut être privilégié.  La distribution ou la divulgation non autorisée de ce courriel est interdite.  Sa divulgation à toute personne autre que son destinataire ne constitue pas une renonciation de privilège.  Si vous avez reçu ce courriel par erreur, veuillez nous aviser et éliminer ce courriel, ainsi que les pièces jointes, de votre système informatique et de vos dossiers.
Skipped content of type multipart/related
