[mapguide-users] Change order of fields displayed in properties pane?
Jo Cook j.cook at oxfordarch.co.uk
Fri Aug 14 12:25:42 EDT 2009
Hi Andrew (and James)
I tried this and couldn't get the change to show up in my web layout. In
fact nothing that I did to the property pane seemed to persist through to
the layout, so clearly something is going wrong that needs more
investigation.
Kenneth- I will need to track down exactly what's happening before I can
report this as any kind of coherent bug- at the moment my observations would
be quite woolly and useless, but I'll see what I can do.
Thanks all
Jo
Andrew DeMerchant wrote:
> Here's a post from James Card to this group from 2006 that's got a
> workaround:
> "The other thing I've done is add leading SPACE charcters to the display
> name for the field in the Layer setup. Since HTML collapses multiple
> spaces into a single space this allows me to specify exactly which order
> they sort in. "
> Andrew
> On 8/14/2009 11:33 AM, Dave Wilson wrote:
>> As far as the AJAX Viewer is concerned the order will still be
>> alphabetical as far as I know. Realistically an enhancement that lets
>> the user drag the fields in the layer editor into an order should
>> actually build the query options with the properties in that order.
>> When they are read from the query the order should stay the same.
>> That's probably and RFC.
>> Dave
>> *From:* mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Kenneth
>> Skovhede, GEOGRAF A/S
>> *Sent:* Friday, August 14, 2009 7:12 AM
>> *To:* MapGuide Users Mail List
>> *Subject:* Re: [mapguide-users] Change order of fields displayed in
>> properties pane?
>> The preview release, since two or three preview releases ago.
>> I don't think the join stuff can influence the order.
>> If you still get unsaved stuff in the preview, be sure to report it,
>> so I can fix it before the next major release.
>> Regards, Kenneth Skovhede, GEOGRAF A/S
>> Jo Cook skrev:
>> It does? Which version? I am currently using the stable version, which is
>> playing hell with the properties- if I change the display name (and save)
>> it
>> sets it back on reload, and none of my changes seem to persist to the
>> viewer. Come to think of it, I'm using a joined layer. Is this likely to
>> be
>> compounding the issue?
>> Thanks
>> Jo
>> Kenneth Skovhede, GEOGRAF A/S wrote:
>>     Maestro supports ordering of the properties, but perhaps the viewer
>>     sorts them afterwards.
>>     James Card skrev:
>>         On Thu, 13 Aug 2009 07:50:21 -0700, Jo
>> Cook<j.cook at oxfordarch.co.uk>  <mailto:j.cook at oxfordarch.co.uk>
>>         wrote:
>>             Is it possible to specify the order in which fields are
>> displayed in
>>             the properties pane? Currently it seems to display them in
>>             alphabetical order, rather than the order in which they
>> appear in the
>>             data source. The only way I can think of getting round it at
>> the
>>             moment is to number all of the properties, which will look a
>> bit
>>             strange...
>>         I don't know of any way to specify the sort order. The workaround
>> we
>>         use, rather than numbering the property names, is to insert
>> leading
>>         spaces in the property names. This causes them to be sorted
>> according
>>         to number of leading spaces, but since HTML collapses whitespace
>> to a
>>         single space the display still looks looks good.
>>     _______________________________________________
>>     mapguide-users mailing list
>>     mapguide-users at lists.osgeo.org
>> <mailto:mapguide-users at lists.osgeo.org>
>>     http://lists.osgeo.org/mailman/listinfo/mapguide-users
> 	*Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
> This e-mail message (including attachments, if any) is confidential and
> may be privileged. Any unauthorized distribution or disclosure is
> prohibited.  Disclosure to anyone other than the intended recipient does
> not constitute waiver of privilege.  If you have received this e-mail in
> error, please notify us and delete it and any attachments from your
> computer system and records.
> Ce courriel (y compris  les pièces jointes) est confidentiel et peut être
> privilégié.  La distribution ou la divulgation non autorisée de ce
> courriel est interdite.  Sa divulgation à toute personne autre que son
> destinataire ne constitue pas une renonciation de privilège.  Si vous avez
> reçu ce courriel par erreur, veuillez nous aviser et éliminer ce courriel,
> ainsi que les pièces jointes, de votre système informatique et de vos
> dossiers.
View this message in context: http://n2.nabble.com/Change-order-of-fields-displayed-in-properties-pane--tp3438480p3446060.html
