[mapguide-users] Change order of fields displayed in properties pane?
Jackie Ng jumpinjackie at gmail.com
Fri Aug 14 18:08:04 EDT 2009
The properties are sorted before being displayed in the properties pane. You
could try commenting out or removing the following line of code to see how
things go.
http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Web/src/viewerfiles/ajaxmappane.templ#L2837
- Jackie
Jo Cook wrote:
> Dear All,
> Is it possible to specify the order in which fields are displayed in the
> properties pane? Currently it seems to display them in alphabetical order,
> rather than the order in which they appear in the data source. The only
> way I can think of getting round it at the moment is to number all of the
> properties, which will look a bit strange...
> Thanks
> Jo
View this message in context: http://n2.nabble.com/Change-order-of-fields-displayed-in-properties-pane--tp3438480p3447722.html
