[mapguide-users] Fusion tiled and dynamic layers same map
GreenMapSanMiguel webmaster at SMAmap.com
Wed Aug 19 11:47:35 EDT 2009
Is it possible to display a mixture of tiled layers and non-tiled layers in
Fusion 2.0?  When I mix base and non-tiled layers in a single Map
Definition:SingleTile "false" nothing is displayed in the map pane - just
the background color legend displays correctly (but turning on layers
doesn't make them appear) select and zoom work for all layers, the overlay
highlight is displayedSingleTile "true" non-tiled layers are displayed in
the map pane legend displays correctly and can turn layers on/off select and
zoom fowk for all layers, the overlay highlight is displayedIf I use two Map
Definitions, one for the tiled layers and one for the non-tiled layers, and
include them both in the MapGroup then only the first map in the MapGroup
displays in the map pane and legend.  Select and zoom only works for layers
in the first map.Does anyone know how to do this?Thanks!  Andy
View this message in context: http://n2.nabble.com/Fusion-tiled-and-dynamic-layers-same-map-tp1815796p3473242.html
