[mapguide-users] Fusion tiled and dynamic layers same map
GreenMapSanMiguel
webmaster at SMAmap.com
Wed Aug 19 11:50:45 EDT 2009
Is it possible to display a mixture of tiled layers and non-tiled layers in
Fusion 2.0?
When I mix base and non-tiled layers in a single Map Definition:
SingleTile "false":
nothing is displayed in the map pane - just the background color
legend displays correctly (but turning on layers doesn't make them appear)
select and zoom work for all layers, the overlay highlight is displayed
SingleTile "true":
non-tiled layers are displayed in the map pane
legend displays correctly and can turn layers on/off
select and zoom wowk for all layers, the overlay highlight is displayed
If I use two Map Definitions, one for the tiled layers and one for the
non-tiled layers, and include them both in the MapGroup then only the first
map in the MapGroup displays in the map pane and legend. Select and zoom
only works for layers in the first map.
Does anyone know how to do this?
Thanks! Andy
View this message in context: http://n2.nabble.com/Fusion-tiled-and-dynamic-layers-same-map-tp1815796p3473267.html
