[mapguide-users] Some tiffs work and others don't - does anybody know why?
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Aug 25 02:44:53 EDT 2009
If you are using GDAL, the debugging trick explained here, should at
least give you a hint:
http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#DebuggingRastersinMapGuide
You can also try the GDalInfo tool, and examine the tiffs for differences:
http://trac.osgeo.org/gdal/wiki/DownloadingGdalBinaries
FWTools is the full package, not sure what minimal packages that have
GdalInfo.
Regards, Kenneth Skovhede, GEOGRAF A/S
Dave Wilson skrev:
> If you are going to place all your images in one folder you should try to ensure they are all the same format, it's not really a requirement, but in terms of reducing the chance of errors and increasing efficiency it is.
> Are you using the GDAL provider?
> Can someone speak to the ideal Tiff format supported by the GDAL provider? Is it Tiled Tiff like MGE and the Autodesk provider or does this not matter?
> Dave
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of JamesDudden
> Sent: Monday, August 24, 2009 2:52 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Some tiffs work and others don't - does anybody know why?
> Hi,
> I am using MG2 with MGStudio9 and have lots of tiffs but some load and some
> don't.
> My process - I click New Data Connection then add the path to the tiffs and
> when I go to view the data some tiffs are there but some give me this error:
> An unclassified exception occurred.
> I installed the FWTools and analysed the tiff that is not working and I have
> posted  the output below but to be honest I don't know what I'm looking at.
> Can anybody help me get these tiffs working?
> Any help or advice is welcome.
> Driver: GTiff/GeoTIFF
> Files: C:\Tiffs\ST02.TIF
>        C:\Tiffs\ST02.TFw
> Size is 4000, 4000
> Coordinate System is `'
> Origin = (300000.000000000000000,140000.000000000000000)
> Pixel Size = (5.000000000000000,-5.000000000000000)
> Metadata:
>   TIFFTAG_IMAGEDESCRIPTION=1:50000 TILE ST02
>   TIFFTAG_DATETIME=2009:06:04 10:52:43
>   TIFFTAG_COPYRIGHT=ORDNANCE SURVEY CROWN COPYRIGHT 2008
>   TIFFTAG_XRESOLUTION=254
>   TIFFTAG_YRESOLUTION=254
>   TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
> Image Structure Metadata:
>   INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left  (  300000.000,  140000.000)
> Lower Left  (  300000.000,  120000.000)
> Upper Right (  320000.000,  140000.000)
> Lower Right (  320000.000,  120000.000)
> Center      (  310000.000,  130000.000)
> Band 1 Block=4000x2 Type=Byte, ColorInterp=Palette
>   Color Table (RGB with 256 entries)
>     0: 216,199,200,255
>     1: 44,19,21,255
>     2: 201,183,185,255
>     3: 184,167,169,255
>     4: 214,10,42,255
>     5: 238,128,144,255
>     6: 222,83,117,255
>     7: 169,121,133,255
>     8: 232,189,200,255
>     9: 137,60,80,255
>    10: 159,93,112,255
>    11: 248,177,200,255
>    12: 229,9,84,255
>    13: 229,40,104,255
>    14: 188,83,120,255
>    15: 243,139,176,255
>    16: 132,88,104,255
>    17: 248,198,216,255
>    18: 231,101,152,255
>    19: 208,145,170,255
>    20: 171,55,102,255
>    21: 80,11,41,255
>    22: 204,51,116,255
>    23: 139,9,69,255
>    24: 231,59,138,255
>    25: 232,8,120,255
>    26: 112,11,61,255
>    27: 215,10,120,255
>    28: 195,9,105,255
>    29: 232,199,217,255
>    30: 245,216,232,255
>    31: 232,12,136,255
>    32: 159,9,97,255
>    33: 46,22,40,255
>    34: 96,70,90,255
>    35: 138,97,130,255
>    36: 61,39,58,255
>    37: 168,117,166,255
>    38: 184,138,183,255
>    39: 201,164,200,255
>    40: 216,197,216,255
>    41: 248,232,248,255
>    42: 24,8,25,255
>    43: 119,92,124,255
>    44: 183,158,200,255
>    45: 69,22,119,255
>    46: 216,202,232,255
>    47: 199,193,216,255
>    48: 90,88,104,255
>    49: 138,136,152,255
>    50: 40,38,58,255
>    51: 167,166,185,255
>    52: 8,8,24,255
>    53: 104,104,120,255
>    54: 104,116,140,255
>    55: 142,151,169,255
>    56: 13,24,41,255
>    57: 61,72,89,255
>    58: 46,84,133,255
>    59: 56,113,153,255
>    60: 141,204,247,255
>    61: 171,216,247,255
>    62: 160,184,201,255
>    63: 76,104,122,255
>    64: 116,200,247,255
>    65: 200,232,248,255
>    66: 60,184,239,255
>    67: 81,189,238,255
>    68: 117,134,142,255
>    69: 193,216,227,255
>    70: 28,184,248,255
>    71: 9,61,82,255
>    72: 61,143,176,255
>    73: 83,123,139,255
>    74: 106,156,177,255
>    75: 8,184,248,255
>    76: 8,151,204,255
>    77: 149,168,175,255
>    78: 10,104,135,255
>    79: 35,184,232,255
>    80: 73,174,205,255
>    81: 184,232,248,255
>    82: 8,183,232,255
>    83: 32,176,215,255
>    84: 41,155,189,255
>    85: 13,42,50,255
>    86: 124,187,205,255
>    87: 8,168,205,255
>    88: 8,148,182,255
>    89: 9,92,112,255
>    90: 9,125,150,255
>    91: 70,88,91,255
>    92: 8,169,183,255
>    93: 39,59,60,255
>    94: 181,200,201,255
>    95: 232,247,248,255
>    96: 8,24,24,255
>    97: 64,183,183,255
>    98: 200,232,232,255
>    99: 216,248,248,255
>   100: 216,232,232,255
>   101: 102,121,120,255
>   102: 174,211,208,255
>   103: 165,186,184,255
>   104: 86,107,104,255
>   105: 118,199,184,255
>   106: 96,182,159,255
>   107: 142,198,182,255
>   108: 134,153,146,255
>   109: 8,165,104,255
>   110: 12,122,74,255
>   111: 196,232,216,255
>   112: 35,182,101,255
>   113: 64,181,103,255
>   114: 87,183,119,255
>   115: 106,182,119,255
>   116: 167,216,173,255
>   117: 116,200,124,255
>   118: 22,42,23,255
>   119: 199,232,200,255
>   120: 8,24,8,255
>   121: 40,56,40,255
>   122: 200,216,200,255
>   123: 232,248,232,255
>   124: 216,217,216,255
>   125: 184,185,184,255
>   126: 145,204,143,255
>   127: 167,186,166,255
>   128: 82,111,80,255
>   129: 58,74,52,255
>   130: 193,216,184,255
>   131: 200,232,184,255
>   132: 118,137,103,255
>   133: 115,193,44,255
>   134: 75,88,64,255
>   135: 200,232,168,255
>   136: 216,231,200,255
>   137: 232,248,216,255
>   138: 194,216,166,255
>   139: 173,210,120,255
>   140: 216,231,184,255
>   141: 162,173,136,255
>   142: 232,248,184,255
>   143: 216,232,159,255
>   144: 146,153,119,255
>   145: 232,248,163,255
>   146: 184,188,166,255
>   147: 181,214,11,255
>   148: 218,231,129,255
>   149: 232,236,200,255
>   150: 217,230,75,255
>   151: 232,248,8,255
>   152: 216,232,8,255
>   153: 232,248,27,255
>   154: 220,231,31,255
>   155: 162,170,50,255
>   156: 211,217,109,255
>   157: 248,247,8,255
>   158: 232,232,8,255
>   159: 206,205,9,255
>   160: 248,248,33,255
>   161: 213,213,53,255
>   162: 248,246,63,255
>   163: 247,245,110,255
>   164: 248,247,146,255
>   165: 248,248,168,255
>   166: 232,232,165,255
>   167: 248,248,184,255
>   168: 216,216,168,255
>   169: 232,232,184,255
>   170: 248,248,200,255
>   171: 200,200,168,255
>   172: 248,248,231,255
>   173: 232,232,216,255
>   174: 72,72,69,255
>   175: 24,24,23,255
>   176: 88,88,85,255
>   177: 120,120,118,255
>   178: 56,56,55,255
>   179: 152,152,150,255
>   180: 200,200,199,255
>   181: 247,244,88,255
>   182: 174,172,88,255
>   183: 110,109,84,255
>   184: 192,182,10,255
>   185: 201,194,80,255
>   186: 130,121,11,255
>   187: 97,90,13,255
>   188: 233,217,46,255
>   189: 163,148,9,255
>   190: 248,227,35,255
>   191: 46,43,18,255
>   192: 175,173,152,255
>   193: 240,214,9,255
>   194: 147,140,86,255
>   195: 248,232,158,255
>   196: 78,66,12,255
>   197: 214,200,151,255
>   198: 232,216,167,255
>   199: 219,174,44,255
>   200: 176,160,116,255
>   201: 248,232,184,255
>   202: 139,133,117,255
>   203: 215,150,9,255
>   204: 198,153,49,255
>   205: 244,195,83,255
>   206: 243,168,9,255
>   207: 156,119,46,255
>   208: 193,152,73,255
>   209: 216,200,168,255
>   210: 248,232,201,255
>   211: 210,172,116,255
>   212: 248,216,168,255
>   213: 232,188,135,255
>   214: 245,203,150,255
>   215: 232,200,168,255
>   216: 201,184,167,255
>   217: 216,200,184,255
>   218: 232,216,200,255
>   219: 214,176,143,255
>   220: 248,184,136,255
>   221: 174,125,92,255
>   222: 248,200,168,255
>   223: 247,168,120,255
>   224: 248,216,196,255
>   225: 232,184,156,255
>   226: 232,168,136,255
>   227: 248,184,152,255
>   228: 232,200,184,255
>   229: 215,90,33,255
>   230: 213,148,119,255
>   231: 85,56,44,255
>   232: 248,168,136,255
>   233: 247,151,115,255
>   234: 127,108,101,255
>   235: 111,87,79,255
>   236: 248,200,184,255
>   237: 171,151,146,255
>   238: 89,71,68,255
>   239: 221,121,111,255
>   240: 248,160,152,255
>   241: 209,144,140,255
>   242: 58,40,39,255
>   243: 230,162,159,255
>   244: 24,8,8,255
>   245: 248,176,176,255
>   246: 248,200,200,255
>   247: 248,216,216,255
>   248: 232,216,216,255
>   249: 142,136,136,255
>   250: 235,232,232,255
>   251: 255,255,255,255
>   252: 168,168,168,255
>   253: 104,104,104,255
>   254: 40,40,40,255
>   255: 8,8,8,255
> http://www.software-matters.co.uk Software Matters  -
> http://www.software-matters.co.uk/bespoke-database-design.html Bespoke
> Database  and Software Solutions
