[mapguide-users] MapGuide, Mapserver and Geoserver
oshan icycool at inbox.com
Wed Aug 26 05:42:28 EDT 2009
Hi Kenneth
Thanks a lot for your reply, it is very informative. At this stage I'm
leaning toward using map guide OS.
On Mon, Aug 24, 2009 at 5:33 PM, Kenneth Skovhede, GEOGRAF A/S (via Nabble)
<ml-user+64672-2082867688 at n2.nabble.com<ml-user%2B64672-2082867688 at n2.nabble.com>
> wrote:
> MapGuide serves the same purpose as MapServer, not sure about Geoserver.
> MapGuide uses FDO to access a (spatial) datastore (eg. database),
> and renders maps (eg. as a PNG image).
> MapGuide is also a service that can expose WMS and WFS.
> MapGuide comes bundles with two viewers,
> one called Flexible weblayout or Fusion viewer
> and one called Basic weblayout or AJAX viewer.
> Fusion is based on OpenLayers, and you can use the official OpenLayers
> viewer "as-is", if you want to.
> MapGuide can run on both IIS and Apache, with a choice of PHP, .Net or JSP
> for server programming language.
> With MapGuide, you can use MapGuide Maestro to set up your map and tools,
> without writing any code (point and click).
> You can then build extra functions, which require coding.
> You can browse the "Getting started" guide here to get a rough idea of the
> process:
> http://mapguide.osgeo.org/2.0/documentation.html
> There is an incomplete Maestro guide here (with screenshots):
> http://trac.osgeo.org/mapguide/wiki/maestro/UserGuide
> I don't know how much coding is involved in setting up a site with other
> servers
> than MapGuide.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> oshan skrev:
> HI I can some please explain me the difference between MapGuide, MapServer
> and Geoserver. I understand that they are all map servers. Also I believe
> that mapguide consist of a browser interface to display the maps. Is this
> similar to openlayers? Are they using openlayers internally? I can sorta
> understand how mapserver or geoserver integrates into a GIS system. For
> example openlayers will be the front end of the GIS system. mapserver or
> geoserver will server the user maps and also somehow pull data from a
> database (ie postGIS) (not sure how this part works?) So is this how
> MapGuide also works? Which of these involve the least coding? Also if I am
> planing to use Apache Tomcat server and JSP for server side scripting which
> of the three will be a good choice? Thanks I eagerly awaits your reposes
> View this message in context: MapGuide, Mapserver and Geoserver<http://n2.nabble.com/MapGuide-Mapserver-and-Geoserver-tp3493774p3493774.html>
> Sent from the MapGuide Users mailing list archive<http://n2.nabble.com/MapGuide-Users-f1803227.html>at Nabble.com.
> mapguide-users mailing list[hidden email] <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=3501877&i=0>http://lists.osgeo.org/mailman/listinfo/mapguide-users
> [hidden email]<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=3501877&i=1>
>  View message @
> http://n2.nabble.com/MapGuide-Mapserver-and-Geoserver-tp3493774p3501877.html
> To unsubscribe from MapGuide, Mapserver and Geoserver, click here< (link removed) ==>.
View this message in context: http://n2.nabble.com/MapGuide-Mapserver-and-Geoserver-tp3493774p3514573.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090826/bfe28dd1/attachment.html
