[mapguide-users] Troubleshooting WMS display problem
Crispin_at_1Spatial crispin.hoult at 1spatial.com
Wed Aug 26 09:46:44 EDT 2009
Jo,
The last time I had WMS issues I was pointed towards GAIA by Tom Fukushima:
http://www.thecarbonproject.com/gaia.php
This helps you to see all the capabilities to check that your WMS server is
serving OK - and should allow you to compare the layers/capabilities with
the WMS service that currently displays and the one from MG that doesn't.
You say all your coord systems are set - so this should not be an issue but
we have seen WMS fail to display in MapGuide where the bounding box at the
individual layer level were defined in a different SRS to the bounding box
at the hop of the capabilities.  Individual layer SRS need to be the same as
the .MapDefinition!  Was that clear?
View this message in context: http://n2.nabble.com/Troubleshooting-WMS-display-problem-tp3514589p3514998.html
