[mapguide-users] Troubleshooting WMS display problem
Jo Cook
j.cook at oxfordarch.co.uk
Wed Aug 26 11:30:47 EDT 2009
Hi Crispin,
Thanks for the heads up about Gaia, that looks very useful, but they are not
my servers so I don't think I can install new software on them.
The sample dataset that I have tried this with is all EPSG 4326, from the
layer definition to the map definition...
Thanks
Jo
Crispin_at_1Spatial wrote:
> Jo,
> The last time I had WMS issues I was pointed towards GAIA by Tom
> Fukushima:
> http://www.thecarbonproject.com/gaia.php
> This helps you to see all the capabilities to check that your WMS server
> is serving OK - and should allow you to compare the layers/capabilities
> with the WMS service that currently displays and the one from MG that
> doesn't.
> You say all your coord systems are set - so this should not be an issue
> but we have seen WMS fail to display in MapGuide where the bounding box at
> the individual layer level were defined in a different SRS to the bounding
> box at the hop of the capabilities. Individual layer SRS need to be the
> same as the .MapDefinition! Was that clear?
View this message in context: http://n2.nabble.com/Troubleshooting-WMS-display-problem-tp3514589p3515262.html
