[mapguide-users] MGOS2.0 and libmysql
Philippe Reinhart
preinhart at environcorp.com
Mon Aug 31 09:10:52 EDT 2009
Windows server 2003 + MGOS2.0 + Mysql 5.0.27
I am trying to connect to a Mysql database using Maestro, but I always
get the same error message:
"The remote server returned an error: (559) MgFdoException.:
An exception occurred in FDO component.
The runtime was not found (module LIBMYSQL.dll). Please verify your
mysql client component installation.
Exception occurred in method MgFdoConnectionManager.Open at line 858 in
file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\common\m
anager\FdoConnectionManager.cpp"
However, I copied libMysql.dll in bin and bin/FDO on the mapguide server
folder.
I also checked that the folder containing libMysql is in the Path var,
but still that doesn't work.
Please help me!
Phil
This message contains information that may be confidential, privileged or otherwise protected by law from disclosure. It is intended for the exclusive use of the Addressee(s). Unless you are the addressee or authorized agent of the addressee, you may not review, copy, distribute or disclose to anyone the message or any information contained within. If you have received this message in error, please contact the sender by electronic reply to email at environcorp.com and immediately delete all copies of the message.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090831/7028e231/attachment.html
