[mapguide-users] Unable to select/highlight objects - MGE
2010Update 1 & AJAX Viewer
Mark Hedges
HedgesM at cityofnorthlasvegas.com
Mon Aug 31 14:11:59 EDT 2009
I have the same issue with both MGE 2009 and 2010. I thought maybe there was a timeout setting or something like that.
-----Original Message-----
From: Praveen Rajendra Babu <prbabu at openspatial.com.au>
To: mapguide-users at lists.osgeo.org <mapguide-users at lists.osgeo.org>
Sent: 8/30/2009 5:23:59 PM
Subject: [mapguide-users] Unable to select/highlight objects - MGE 2010Update 1 & AJAX Viewer
This is happening quite regularly and thought of bringing to the group's notice.
When I leave MGE idle, like overnight and the next day morning when I try to access
the map, it displays perfectly fine. But when I try to select a feature on the map
it shows "x" feature selected, but the object is not highlighted on the map. Also,
any MGE API operations with the selected non-highlighted object fails.
To resolve the issue, I re-start BOTH MGE server and WWW services.
I have recently applied the MGE 2010 Update 1 and can't remember anything like this
prior to the update.
The server Error.log has the below consistent message:
Error: The requested operation version is invalid.
StackTrace:
- MgOperationThread.ProcessOperation() line 431 file d:\build\testarossa_nightly\build_35.5\ent\os\server\src\core\OperationThread.cpp
- MgFeatureServiceHandler.ProcessOperation() line 83 file d:\build\testarossa_nightly\build_35.5\ent\os\server\src\services\feature\FeatureServiceHandler.cpp
- MgFeatureOperationFactory.GetOperation() line 445 file d:\build\testarossa_nightly\build_35.5\ent\os\server\src\services\feature\FeatureOperationFactory.cpp
Please let me know if you want me to enable more logging detail, if that helps.
System details:
MapGuide Server Version: 2.1.0.3505
MapGuide AJAX Viewer Version: 2.1.0.3505
OS: Windows Server 2003 Standard Edition SP 2
IIS Server : V6.0
Thanks for your time.
Regards,
Praveen
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
