[mapguide-users] SHP Feature source update
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Dec 1 02:58:30 EST 2009
"Invalid stream header exception" is usually an indication that you
are using an incompatible version of the WebAPI dlls.
Eg. You install MGOS 2.0, and copy the dll's to your project.
You then upgrade to MGOS 2.1, but forget to upgrade the dll's.
Regards, Kenneth Skovhede, GEOGRAF A/S
smeurant skrev:
> I made the change.
> I still have a "Invalid stream header exception" but the new feature is
> successfully added to the feature source .
> I will check where the exception come from and I will update my post later.
> Thanks for your help Kenneth.
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> MgLayer is the name of the class that is used for runtime layers.
>> Im guessing that layer.GetClassName() returns "MgLayer".
>> Have you tried with GetFeatureClassName():
>> http://mapguide.osgeo.net/files/mapguide/docs/webapi/d6/de2/class_mg_layer_a983e24398d337eff4809830993eb992.html#a983e24398d337eff4809830993eb992
>> smeurant skrev:
>>> Hi all,
>>> I try to update a SHP feature source using the MapGuide Java API with a
>>> servlet.
>>> But i have a problem with this step :
>>> featureService.UpdateFeatures(FeatureSourceID,featureCommandCollection,false);
>>> Like say the API doc , it return a MgPropertyCollection.
>>> And in this propertyCollection, i found a error msg sent by FDO :
>>> An exception occurred in FDO component.
>>> FDO class 'MgLayer' not found in schema.
>>> Is the problem come from my implementation or, is it a bug in MGOS 2.1b?
>>> P.S : You can find the full servlet implementation in the attached file
>>> http://n2.nabble.com/file/n4076428/updateFeatureSource.java
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091201/52af4b96/attachment.html
