[mapguide-users] WMS and Failed to stylize layer in EPSG 31467 on MGOS 2.1
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Dec 1 03:03:06 EST 2009
2.x is a more demanding in terms of coordinate system compatibility.
Previously, you were allowed to have empty coordinate systems.
If your map has the correct coordinate system specified, you
can check all your FeatureSource items to see if they have the correct
projection defined, otherwise add a "coordinate system override".
If you use the preview version of Maestro, you can run the
validation tool on the map (big green V icon), and it will
tell you what if a FeatureSource has a different coordinate system.
Regards, Kenneth Skovhede, GEOGRAF A/S
Axel Dörr skrev:
> *Montag, 30.11.2009*
> Hello List,
> I need some express help.
> I´ve updated MGOS 1.X to 2.1 on Windows 2000 Server with IIS5.
> Everything is fine now except for the WMS-Service which I deliver.
> There are no rasterimages involved.
> In the trace.log I find the following error:
> Error: Failed to stylize layer: path and name of layer
>         The coordinate system initialization failed.
>         Could not initialize the geodetic transformation
> The Coordinates are in EPSG:31467 (Germany, Gauss-Krueger).
> In MG Studio 2009, the definition of the serviceproperties looks like
> this:
> <Bounds SRS="EPSG:31467" west="3556600" south="5374600" east="3557700"
> north="5375600"/>
> This worked fine with MGOS 1.X.
> What has changed with MGOS 2.1 and which settings will be needed now?
> Thanks for help!
> Regards,
> Axel
> Dörr Ingenieurbüro
> Siebenmuehlenstraße 36
> 70771 Leinfelden-Echterdingen
> Tel: +49 (0)711 99 760 7-60
> Fax: +49 (0)711 99 760 7-80
> Email: mailto:info at doerrib.de
> Web: http://www.doerrib.de
> Diese E-Mail enthält vertrauliche und/oder rechtlich geschützte
> Informationen. Wenn Sie nicht der richtige Adressat sind oder diese
> E-Mail irrtümlich erhalten haben, informieren Sie bitte sofort den
> Absender und vernichten diese Mail. Das unerlaubte Kopieren sowie die
> unbefugte Weitergabe dieser Mail ist nicht gestattet.
> This e-mail may contain confidential and/or privileged information. If
> you are not the intended recipient (or have received this e-mail in
> error) please notify the sender immediately and destroy this e-mail.
> Any unauthorised copying, disclosure or distribution of the material
> in this e-mail is strictly forbidden.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091201/095dd012/attachment.html
