[mapguide-users] Raster problems with MGOS 2.1
isca
mapguide2007 at gmail.com
Tue Dec 1 06:26:27 EST 2009
Helllo Kenneth,
I will certainly try this out but I don't know if I can use it for
production. I guess it will bring down the performance of the vector layers
also.
Maybe I could try it out with adding the GDAL provider to the
DataConnectionPoolExcludedProviders list.
Kenneth Skovhede, GEOGRAF A/S wrote:
> Have you tried the trick Jason posted?
> "I had to set DataConnectionPoolEnabled to 0 under the
> FeatureServiceProperties section of serverconfig.ini to get my install
> stable."
> Regards, Kenneth Skovhede, GEOGRAF A/S
> isca skrev:
>> I have upgraded my MGOS 2.0.1 towards 2.1 and the improvement in speed is
>> incredible. But the problem child of MGOS since the beginning seems still
>> to
>> exist -> rasters. When turning raster layers on/off in the viewer I get
>> very
>> fast an error indicating "can make no more connections to GDAL provider".
>> Although the service doesn't crash anymore the web api seems to stuck.
>> Is there a way to overcome this problem (increasing the number of allowed
>> connections ?) ?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Raster-problems-with-MGOS-2-1-tp4079477p4093097.html
