[mapguide-users] Raster problems with MGOS 2.1
Zac Spitzer zac.spitzer at gmail.com
Tue Dec 1 07:05:17 EST 2009
I'd say file a new bug, referencing this one which has been closed
http://trac.osgeo.org/mapguide/ticket/462
z
2009/12/1 isca <mapguide2007 at gmail.com>:
> Helllo Kenneth,
> I will certainly try this out but I don't know if I can use it for
> production. I guess it will bring down the performance of the vector layers
> also.
> Maybe I could try it out with adding the GDAL provider to the
> DataConnectionPoolExcludedProviders list.
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> Have you tried the trick Jason posted?
>> "I had to set DataConnectionPoolEnabled to 0 under the
>> FeatureServiceProperties section of serverconfig.ini to get my install
>> stable."
>> Regards, Kenneth Skovhede, GEOGRAF A/S
>> isca skrev:
>>> I have upgraded my MGOS 2.0.1 towards 2.1 and the improvement in speed is
>>> incredible. But the problem child of MGOS since the beginning seems still
>>> to
>>> exist -> rasters. When turning raster layers on/off in the viewer I get
>>> very
>>> fast an error indicating "can make no more connections to GDAL provider".
>>> Although the service doesn't crash anymore the web api seems to stuck.
>>> Is there a way to overcome this problem (increasing the number of allowed
>>> connections ?) ?
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> View this message in context: http://n2.nabble.com/Raster-problems-with-MGOS-2-1-tp4079477p4093097.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
