[mapguide-users] Problem setting up connection with Maestro and
SL King Oracle Provider
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Wed Dec 2 03:18:45 EST 2009
Are you sure you are using MGOS 2.1 final?
I think there was a similar error in a previous version of MGOS 2.1 (and
MGEP 2010).
In any case, the message displayed by Maestro is a warning, and you
should be able to save anyway.
Regards, Kenneth Skovhede, GEOGRAF A/S
Flavio Hendry skrev:
> Hi all
> I trying to setup a new resource with the SL King Oracle FDO Provider.
> I can setup the connection and test it and it works ("Provider reports
> no errors"). However I cannot save the connection. I get the following
> errors from Maestro (many of the same): "Failed to read entity
> properties: The remote server returned an error:
> (559)MgClassNotFoundException: The specified class was not found."
> - MG OS 2.1
> - Maestro 1.1.0.4358
> Thanks for any help.
> Mit herzlichen Grüssen / Best Regards
> Flavio Hendry
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
