[mapguide-users] Problem setting up connection with Maestro and SL King Oracle Provider
Flavio Hendry flavio at hendry.ch
Thu Dec 3 04:25:32 EST 2009
Hi Kenneth
> The message box is a standard Yes/No/Cancel messagebox which asks if
> you want to save anyway, so you can press Enter to get the default
> button (which is Yes), or press Y (or whatever shortcut key Yes has
> in your local version of Windows).
Thanks! This was indeed the problem, I just pressed enter and there you
go. Perfect!
Mit herzlichen Grüssen / Best Regards
Flavio Hendry
