[mapguide-users] Installation error
Thomas Lorenzon thomas.lorenzon at gmail.com
Thu Dec 3 10:28:16 EST 2009
Hi All, I have another solution.
If you don't have any particular IIS installation, you can unistall and
reinstall IIS.
Then install MapGuide.
It works for me (Windows Server 2003 + IIS 6).
Thomas
Jason Birch wrote:
> Copy of my answer on "Internals":
> The installer requires that the default website still exists; for IIS6
> this
> means that both the internal ID and name are unchanged from the default.
>  IIS7 I think only requires that the name is available. The important
> variables are SITE_ID and MG_WEBSITE:
> http://trac.osgeo.org/mapguide/browser/branches/2.1/Installer/Installers/MapGuide/MapGuide.wxs#L51
> Which are used in:
> IIS6:
> http://trac.osgeo.org/mapguide/browser/branches/2.1/Installer/Libraries/MapGuide%20Web%20Extensions/IIS.wxs
> IIS7:
> http://trac.osgeo.org/mapguide/browser/branches/2.1/Installer/Libraries/MapGuide%20Web%20Extensions/IIS7.wxs
> If you have renamed or deleted the default site, the installation will
> fail.
>  One of the wishlist items for the installer is a dropdown of websites to
> choose from, but it will require some development work.
> In the meantime, you can perform a manual install, and configure the IIS
> integration manually.  This is a bit of a pain and not well documented;
> perhaps we should look at setting up some scripts that could be easily
> edited and run by users for this...
> If you haven't renamed / deleted the default website, we'll need you to
> enable the Windows Installer log and try again, providing us with a
> location
> to download the log from. This page shows how to enable MSI logging:
> http://support.microsoft.com/kb/223300
> Jason
> 2009/11/25 Flipper <scotth at mpowerinnovations.com>
>> Sorry Windows 200 Server on this one
>> Flipper wrote:
>> > Let me reword that a little when i said host headears I meant
>> subdomains
>> > gis.website.com wiki.website.com etc.
>> > Flipper wrote:
>> >> I'm having the same problem...We are using host headers I changed the
>> >> default back to All unassigned and its still Giving me the rollback
>> after
>> >> the  Failed while
>> >> processing WebVirtualDirs (-2147024894).
>> >> HELP!!!!
>> >> Fraser Burgess wrote:
>> >>> Hi All,
>> >>> I get the following error when installing MGOS2.1:  Failed while
>> >>> MGOS2.1 - IIS / .NET configuration
>> >>> Windows Server 2003 SP2
>> >>> After clicking the okay button on the error message the install rolls
>> >>> back
>> >>> Any ideas on how to fix?
>> >>> Fraser
>> >>> _______________________________________________
>> >>> mapguide-users mailing list
>> >>> mapguide-users at lists.osgeo.org
>> >>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> View this message in context:
>> http://n2.nabble.com/Installation-error-tp3858392p4066230.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
View this message in context: http://n2.nabble.com/Installation-error-tp3858392p4106684.html
