[mapguide-users] problem about maestro + mysql
Dave Wilson dave.wilson at autodesk.com
Thu Dec 3 12:59:09 EST 2009
An alternative should be to install the MySQL Query browser which also uses the same dll, but adds an entry to the system path instead of the user having to copy it to the FDO folder. Of course which version is somewhat important to get the right version of the dll. With the Query browser you have a way to checking your database connectivity independent of MapGuide.
Regards,
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of xjimmyshcn
Sent: Wednesday, December 02, 2009 6:21 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] problem about maestro + mysql
yeah,you are right.
Here is what I do:
1.uninstall MapGuideOpenSource-2.1.0.4283-Final ,and reinstall( select mysql
provider in FDO during install)
2.cpoy c:\Program Files\MySQL\MySQL Server 5.0\bin\libmySQL.dll to
C:\Program Files\OSGeo\MapGuide\Server\bin\
then ok
thank you!
xjimmyshcn wrote:
> environmen:
> mapguide maestro 1.1.0.4358
> fdomysql-win32-3.4.1(FDO Provider for MySQL )
> mysql-5.0.88-win32
> when i add a data connection in “mapguide maestro ”,after i set the right
> info about mysql(server,database,username,password),i press “Test
> connection”,the return information is:
>  (559) MgFdoException。:
> An exception occurred in FDO component.
> RDBMS: Invalid object type to describe.
> is there anybody meet the same problem?
>  :confused:
View this message in context: http://n2.nabble.com/problem-about-maestro-mysql-tp4097913p4103503.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
