[mapguide-users] Successful MGOS 2.1 install
Jonio, Dennis (Aviation) DJonio at miami-airport.com
Thu Dec 3 15:59:34 EST 2009
Yes it is and it works just fine ... but I wanted to play/test/do the
"DotNet" function thingees ... they do the mapviewernet app directly
r,
dennis
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Thursday, December 03, 2009 3:54 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Successful MGOS 2.1 install
MapAgent should be accessible under /mapguide/mapagent/mapagent.fcgi
with the tests under /mapguide/mapagent/index.html (or something like
that)?
For some subset of functionality (that used by developers and active
testers) Fusion works great, and is a lot faster than previous versions
especially if you do a custom build. There are still performance
problems with maps containing large numbers of layers, and there are
probably lots and lots of edge cases out there to be stumbled over.
It's a bit of chicken and egg.  If people don't start using/testing it,
the problems won't get found and fixed.  Of course, if they're found
there also needs to be reproducible test cases submitted to the Fusion
Trac instance, developer time to address, etc, so I wouldn't go into a
Fusion project expecting rapid deployment unless I had resources to
throw at it.
Jason
2009/12/3 djonio
Jason,
Is mapviewerajax set up as an alias to mapviewernet and set as an
application?
Yes it is/was. I wanted to play with mapagent.
What is your opinion: Do I dare work with fusion?
r,
dennis
Scan by McAfee
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091203/b1539c8b/attachment.html
