[mapguide-users] Successful MGOS 2.1 install
Jason Birch
jason at jasonbirch.com
Thu Dec 3 15:53:45 EST 2009
MapAgent should be accessible under /mapguide/mapagent/mapagent.fcgi with
the tests under /mapguide/mapagent/index.html (or something like that)?
For some subset of functionality (that used by developers and active
testers) Fusion works great, and is a lot faster than previous versions
especially if you do a custom build. There are still performance problems
with maps containing large numbers of layers, and there are probably lots
and lots of edge cases out there to be stumbled over.
It's a bit of chicken and egg. If people don't start using/testing it, the
problems won't get found and fixed. Of course, if they're found there also
needs to be reproducible test cases submitted to the Fusion Trac instance,
developer time to address, etc, so I wouldn't go into a Fusion project
expecting rapid deployment unless I had resources to throw at it.
Jason
2009/12/3 djonio
> Jason,
> Is mapviewerajax set up as an alias to mapviewernet and set as an
> application?
> Yes it is/was. I wanted to play with mapagent.
> What is your opinion: Do I dare work with fusion?
> r,
> dennis
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091203/8652fbb7/attachment.html
