[mapguide-users] MGOS 2.1.0.4238 PROBLEM
balaji bitra
bitbalaji at gmail.com
Fri Dec 4 00:07:37 EST 2009
hi
thanks for reply...
i am using correct .net framework version. and screenshot is:
http://n2.nabble.com/file/n4110626/mgos.bmp
i completely uninstall the MGOS2.0 and remove the "mapguide"folder in
program files.
After that restrat the system then i installed the mgos 2.1.0.4238.
and i also installed the MGOS 2.1.0.4238 in the new system which didnot have
the mgos2.0 , in that also the same problem.
if the iis is the problem then the application won't be work on MGOS2.0,but
its working.....
thanks Again
Balaji
View this message in context: http://n2.nabble.com/MGOS-2-1-0-4238-PROBLEM-tp4104120p4110626.html
