[mapguide-users] Problem with the dwf viewer and a reverse proxy.
Gabriele Monfardini
gabrimonfa at gmail.com
Fri Dec 4 06:40:16 EST 2009
> Problem :
> The dwf viewer does not display the map, it displays all the other
> frames correctly, i.e tbFrame, taskFrame and from the mapFrame only
> the Layers and Properties panes. The ajax viewer works
> perfectly.
> I have noticed in the logs of the apache server that the dwf viewer
> tries to access directly the server that is behind the
> firewall, http://mapguideserver:8008/mapguide,
> not the alias that is configured in the proxy,
> http://mapguideexternalalias/mapguide.
> This happens only one time when the dwf viewer tries to get the map.
> Request:
> Does anyone have a solution or a hint or something that my help ?
> Thanks.
We've had the same problem.
Our solution was to modify two values inside mapguide-apache httpd.conf.
ServerName should be your "mapguideexternalalias" (the URL of the
apache that is configured to access mapguide via proxy)
UseCanonicalName should be On
In this way self-referencing URL will be constructed using ServerName
Regards,
Gabriele
