[mapguide-users] Connection Problem
Zac Spitzer
zac.spitzer at gmail.com
Mon Dec 7 02:32:53 EST 2009
2009/12/7 manav dayal <manav_dayal85 at yahoo.co.in>
> Exactly which add on are you recommeding Zac.
> There are so many available.
> I have installed firebug but haven't found the net tab.
http://www.google.com.au/search?hl=en&q=firebug+net+tab
> I am not getting your point.
> Thanks and Regards.
> --- On *Mon, 7/12/09, Zac Spitzer <zac.spitzer at gmail.com>* wrote:
> From: Zac Spitzer <zac.spitzer at gmail.com>
> Subject: Re: [mapguide-users] Connection Problem
> To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
> Date: Monday, 7 December, 2009, 12:35 PM
> ok, can you install the firebox addon and enable the net tab,
> often is can be a missing file, which should show up in red
> under the net tab
> z
> 2009/12/7 manav dayal <manav_dayal85 at yahoo.co.in<http://in.mc941.mail.yahoo.com/mc/compose?to=manav_dayal85@yahoo.co.in>
>> I tried it on Firefox
>> It is showing the following error on the console:
>> Error: parent.parent.mapFrame is undefined
>> Source File:
>> http://192.168.224.24:8008/mapguide/javasamples/common/pageLoadFunctions.js
>> Line: 25
>> Rest of them are warnings.
>> I am attaching the ScreenShot as well.
>> Thanks and Regards.
>> --- On *Mon, 7/12/09, Zac Spitzer <zac.spitzer at gmail.com<http://in.mc941.mail.yahoo.com/mc/compose?to=zac.spitzer@gmail.com>
>> >* wrote:
>> From: Zac Spitzer <zac.spitzer at gmail.com<http://in.mc941.mail.yahoo.com/mc/compose?to=zac.spitzer@gmail.com>
>> To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org<http://in.mc941.mail.yahoo.com/mc/compose?to=mapguide-users@lists.osgeo.org>
>> Date: Monday, 7 December, 2009, 11:25 AM
>> 302 is a just a redirect, not an error, so I wouldn't worry so much about
>> that
>> I note you mentioned using IE, does using Firefox make any difference?
>> Anything show up in the firefox error console?
>> z
>>> When I try the link
>>> http://192.168.224.24:8008/mapguide/javasamples/main.jsp
>>> from the machine with ip 192.168.224.135 it is giving the error ( IE
>>> cannot display the webpage)
>>> it gives only 3 entries in the access log of apache installed on my
>>> machine with ip 192.168.224.24
>>> Following are the entries:
>>> 192.168.224.135 - - [07/Dec/2009:10:34:31 +0530] "GET
>>> /mapguide/javasamples/main.jsp HTTP/1.1" 200 880
>>> /mapguide/gis1/styles/globalStyles.css HTTP/1.1" 404 1066
>>> /mapguide/mapviewerajax/?SESSION=edc0ff8a-ffff-ffff-8000-0018f319f820_en_7F0000010AFC0AFB0AFA&WEBLAYOUT=Library://Samples/ms/Layouts/ms.WebLayout
>>> HTTP/1.1" 302 472
>>> But When I try the link http://192.168.224.24
>>> :8008/mapguide/javasamples/main.jsp<http://:8008/mapguide/javasamples/main.jsp>
>>> from my machine it is creating lot of entries in the access log of
>>> apache.
>>> Comparing the entries is not helping the cause.
>>> I could not figure out where the problem is?
>>> Plz help!!!
>>> Thanks and Regards.
>>> --- On *Fri, 4/12/09, manav dayal <manav_dayal85 at yahoo.co.in<http://in.mc941.mail.yahoo.com/mc/compose?to=manav_dayal85@yahoo.co.in>
>>> >* wrote:
>>> From: manav dayal <manav_dayal85 at yahoo.co.in<http://in.mc941.mail.yahoo.com/mc/compose?to=manav_dayal85@yahoo.co.in>
>>> Date: Friday, 4 December, 2009, 4:43 PM
>>> There is an entry in the access logs of apache which says:
>>> 192.168.224.135 - - [04/Dec/2009:14:58:51 +0530] "GET
>>> /mapguide/mapviewerajax/?SESSION=5b777a88-0000-1000-8000-0018f319f820_en_7F0000010AFC0AFB0AFA&WEBLAYOUT=
>>> *Library://Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout HTTP/1.1"
>>> 302 489*
>>> How can I resolve this status code 302 error.
>>> Googling hasn't helped.
>>> *I haven't found any relevant entry in the Logs of Tomcat and MGOS 2.0.
>>> Still stuck!!
>>> I am in my learning stage Zac.
>>> Pardon me.
>>> Thanks for all the help!!
>>> Regards.
>>> --- On *Fri, 4/12/09, Zac Spitzer <zac.spitzer at gmail.com<http://in.mc941.mail.yahoo.com/mc/compose?to=zac.spitzer@gmail.com>
>>> Date: Friday, 4 December, 2009, 10:45 AM
>>> time for you to do some debugging, if your using the java samples,
>>> I'd assume you know a bit about programming jsp
>>> there are error logs from both your webserver, servlet container
>>> 2009/12/4 manav dayal <manav_dayal85 at yahoo.co.in<http://in.mc941.mail.yahoo.com/mc/compose?to=manav_dayal85@yahoo.co.in>
>>>> Oops! This link appears to be broken.
>>>> is the error I am getting Zac.
>>>> The link *http://ip:8008/mapguide/* is working fine.
>>>> and showing the list of the directories.
>>>> But when I try the link *http://ip:8008/mapguide/javasamples/main.jsp*
>>>> is giving the above error.
>>>> Help!!
>>>> Date: Friday, 4 December, 2009, 9:44 AM
>>>> how about a little more detail that just saying it 'errors' ?
>>>> 2009/12/4 manav dayal <manav_dayal85 at yahoo.co.in<http://mc/compose?to=manav_dayal85@yahoo.co.in>
>>>>> Hi everyone.
>>>>> I am stuck with this.
>>>>> Plz help!!
>>>>> Thanks in advance.
>>>>> Regards.
>>>>> --- On *Thu, 3/12/09, manav dayal <manav_dayal85 at yahoo.co.in<http://mc/compose?to=manav_dayal85@yahoo.co.in>
>>>>> >* wrote:
>>>>> From: manav dayal <manav_dayal85 at yahoo.co.in<http://mc/compose?to=manav_dayal85@yahoo.co.in>
>>>>> Subject: [mapguide-users] Connection Problem
>>>>> To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org<http://mc/compose?to=mapguide-users@lists.osgeo.org>
>>>>> Date: Thursday, 3 December, 2009, 6:08 PM
>>>>> I have MGOS 2.0 installed on my machine and my sample application
>>>>> is running fine
>>>>> on my machine using apache and tomcat.
>>>>> When I try to access the same application from another machine by
>>>>> providing the
>>>>> IP Address of the my machine in the url
>>>>> it gives link broken type of errors.
>>>>> http://ip/ gives a page which shows *It works!*
>>>>> even
>>>>> http://ip/mapguide/ shows the *listing of the directories.*
>>>>> but when i try to access
>>>>> http://ip/mapguide/javasamples/main.jsp
>>>>> it gives errors but works on my machine.
>>>>> can anyone help!!!
>>>>> Thanks and Regards.
>>>>> The INTERNET now has a personality. YOURS! See your Yahoo! Homepage<http://in.rd.yahoo.com/tagline_yyi_1/*http://in.yahoo.com/>
>>>>> -----Inline Attachment Follows-----
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>> Zac Spitzer
>>>> Solution Architect / Director
>>>> Ennoble Consultancy Australia
>>>> http://www.ennoble.com.au
>>>> http://zacster.blogspot.com
>>>> +61 405 847 168
>>> Zac Spitzer
>>> +61 405 847 168
>> Zac Spitzer
>> +61 405 847 168
> Zac Spitzer
> +61 405 847 168
Zac Spitzer
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091207/1c035500/attachment.html
