[mapguide-users] Connection Problem
manav dayal
manav_dayal85 at yahoo.co.in
Mon Dec 7 02:36:16 EST 2009
Zac
I am unable to view any map using different machine.
Thanks and Regards.
--- On Mon, 7/12/09, Zac Spitzer <zac.spitzer at gmail.com> wrote:
Subject: Re: [mapguide-users] Connection Problem
To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
Date: Monday, 7 December, 2009, 12:42 PM
looking at yourscreenshot again, it appears the problem is the sample code is hardwired to refer to
localhost:8008 hence the problem...
can you view a normal map without using the javasamples from another machine?
2009/12/7 Zac Spitzer <zac.spitzer at gmail.com>
ok, can you install the firebox addon and enable the net tab,
often is can be a missing file, which should show up in red
under the net tab
z
2009/12/7 manav dayal <manav_dayal85 at yahoo.co.in>
I tried it on Firefox
It is showing the following error on the console:
Error: parent.parent.mapFrame is undefined
Source File: http://192.168.224.24:8008/mapguide/javasamples/common/pageLoadFunctions.js
Line: 25
Rest of them are warnings.
I am attaching the ScreenShot as well.
Thanks and Regards.
Date: Monday, 7 December, 2009, 11:25 AM
302 is a just a redirect, not an error, so I wouldn't worry so much about that
I note you mentioned using IE, does using Firefox make any difference?
Anything show up in the firefox error console?
z
When I try the link http://192.168.224.24:8008/mapguide/javasamples/main.jsp
from the machine with ip 192.168.224.135 it is giving the error ( IE cannot display the webpage)
it gives only 3 entries in the access log of apache installed on my machine with ip 192.168.224.24
Following are the entries:
192.168.224.135 - - [07/Dec/2009:10:34:31 +0530] "GET /mapguide/javasamples/main.jsp HTTP/1.1" 200 880
192.168.224.135 - - [07/Dec/2009:10:34:31 +0530] "GET /mapguide/gis1/styles/globalStyles.css HTTP/1.1" 404 1066
192.168.224.135 - - [07/Dec/2009:10:34:31 +0530] "GET /mapguide/mapviewerajax/?SESSION=edc0ff8a-ffff-ffff-8000-0018f319f820_en_7F0000010AFC0AFB0AFA&WEBLAYOUT=Library://Samples/ms/Layouts/ms.WebLayout HTTP/1.1" 302 472
But When I try the link http://192.168.224.24:8008/mapguide/javasamples/main.jsp
from my machine it is creating lot of entries in the access log of apache.
Comparing the entries is not helping the cause.
I could not figure out where the problem is?
Plz help!!!
Thanks and Regards.
Date: Friday, 4 December, 2009, 4:43 PM
There is an entry in the access logs of apache which says:
192.168.224.135 - - [04/Dec/2009:14:58:51 +0530] "GET /mapguide/mapviewerajax/?SESSION=5b777a88-0000-1000-8000-0018f319f820_en_7F0000010AFC0AFB0AFA&WEBLAYOUT=Library://Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout HTTP/1.1" 302 489
How can I resolve this status code 302 error.
Googling hasn't helped.
I haven't found any relevant entry in the Logs of Tomcat and MGOS 2.0.
Still stuck!!
I am in my learning stage Zac.
Pardon me.
Thanks for all the help!!
Regards.
Date: Friday, 4 December, 2009, 10:45 AM
time for you to do some debugging, if your using the java samples,
I'd assume you know a bit about programming jsp
there are error logs from both your webserver, servlet container
2009/12/4 manav dayal <manav_dayal85 at yahoo.co.in>
Oops! This link appears to be broken.
is the error I am getting Zac.
The link http://ip:8008/mapguide/ is working fine.
and showing the list of the directories.
But when I try the link http://ip:8008/mapguide/javasamples/main.jsp
is giving the above error.
Help!!
Date: Friday, 4 December, 2009, 9:44 AM
how about a little more detail that just saying it 'errors' ?
Hi everyone.
I am stuck with this.
Plz help!!
Thanks in advance.
Regards.
--- On Thu, 3/12/09, manav dayal <manav_dayal85 at yahoo.co.in> wrote:
Subject: [mapguide-users] Connection Problem
Date: Thursday, 3 December, 2009, 6:08 PM
I have MGOS 2.0 installed on my machine and my sample application is running fine
on my machine using apache and tomcat.
When I try to access the same application from another machine by providing the
IP Address of the my machine in the url
it gives link broken type of errors.
http://ip/ gives a page which shows It works!
even
http://ip/mapguide/ shows the listing of the directories.
but when i try to access
http://ip/mapguide/javasamples/main.jsp
it gives errors but works on my machine.
can anyone help!!!
Thanks and Regards.
The INTERNET now has a personality. YOURS! See your Yahoo! Homepage.
-----Inline Attachment Follows-----
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
Zac Spitzer
+61 405 847 168
Zac Spitzer
+61 405 847 168
Zac Spitzer
+61 405 847 168
Zac Spitzer
+61 405 847 168
The INTERNET now has a personality. YOURS! See your Yahoo! Homepage. http://in.yahoo.com/
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091207/0b27b261/attachment.html
