[mapguide-users] Connection Problem
manav dayal
manav_dayal85 at yahoo.co.in
Mon Dec 7 07:23:05 EST 2009
The problem is still haunting me.
I have tried to peep into the code but all in vain.
Wtih the help of logs I derived that out of the 3 entries,any entry for the ajaxviewer.jsp is missing.
Is the session information not passing appropriately or ????
Installed the addon firebug and viewed the net tab, but information is unavailable in the tab.
Thaks and Regards.
--- On Mon, 7/12/09, manav dayal <manav_dayal85 at yahoo.co.in> wrote:
Subject: Re: [mapguide-users] Connection Problem
To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
Date: Monday, 7 December, 2009, 1:06 PM
Zac
I am unable to view any map using different machine.
Thanks and Regards.
Date: Monday, 7 December, 2009, 12:42 PM
looking at yourscreenshot again, it appears the problem is the sample code is hardwired to refer to
localhost:8008 hence the problem...
can you view a normal map without using the javasamples from another machine?
2009/12/7 Zac Spitzer <zac.spitzer at gmail.com>
ok, can you install the firebox addon and enable the net tab,
often is can be a missing file, which should show up in red
under the net tab
z
2009/12/7 manav dayal <manav_dayal85 at yahoo.co.in>
I tried it on Firefox
It is showing the following error on the console:
Error: parent.parent.mapFrame is undefined
Source File: http://192.168.224.24:8008/mapguide/javasamples/common/pageLoadFunctions.js
Line: 25
Rest of them are warnings.
I am attaching the ScreenShot as well.
Thanks and Regards.
Date: Monday, 7 December, 2009, 11:25 AM
302 is a just a redirect, not an error, so I wouldn't worry so much about that
I note you mentioned using IE, does using Firefox make any difference?
Anything show up in the firefox error console?
z
When I try the link http://192.168.224.24:8008/mapguide/javasamples/main.jsp
from the machine with ip 192.168.224.135 it is giving the error ( IE cannot display the webpage)
it gives only 3 entries in the access log of apache installed on my machine with ip 192.168.224.24
Following are the entries:
192.168.224.135 - - [07/Dec/2009:10:34:31 +0530] "GET /mapguide/javasamples/main.jsp HTTP/1.1" 200 880
192.168.224.135 - - [07/Dec/2009:10:34:31 +0530] "GET /mapguide/gis1/styles/globalStyles.css HTTP/1.1" 404 1066
192.168.224.135 - - [07/Dec/2009:10:34:31 +0530] "GET /mapguide/mapviewerajax/?SESSION=edc0ff8a-ffff-ffff-8000-0018f319f820_en_7F0000010AFC0AFB0AFA&WEBLAYOUT=Library://Samples/ms/Layouts/ms.WebLayout HTTP/1.1" 302 472
But When I try the link http://192.168.224.24:8008/mapguide/javasamples/main.jsp
from my machine it is creating lot of entries in the access log of apache.
Comparing the entries is not helping the cause.
I could not figure out where the problem is?
Plz help!!!
Thanks and Regards.
Date: Friday, 4 December, 2009, 4:43 PM
There is an entry in the access logs of apache which says:
192.168.224.135 - - [04/Dec/2009:14:58:51 +0530] "GET /mapguide/mapviewerajax/?SESSION=5b777a88-0000-1000-8000-0018f319f820_en_7F0000010AFC0AFB0AFA&WEBLAYOUT=Library://Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout HTTP/1.1" 302 489
How can I resolve this status code 302 error.
Googling hasn't helped.
I haven't found any relevant entry in the Logs of Tomcat and MGOS 2.0.
Still stuck!!
I am in my learning stage Zac.
Pardon me.
Thanks for all the help!!
Regards.
Date: Friday, 4 December, 2009, 10:45 AM
time for you to do some debugging, if your using the java samples,
I'd assume you know a bit about programming jsp
there are error logs from both your webserver, servlet container
2009/12/4 manav dayal <manav_dayal85 at yahoo.co.in>
Oops! This link appears to be broken.
is the error I am getting Zac.
The link http://ip:8008/mapguide/ is working fine.
and showing the list of the directories.
But when I try the link http://ip:8008/mapguide/javasamples/main.jsp
is giving the above error.
Help!!
Date: Friday, 4 December, 2009, 9:44 AM
how about a little more detail that just saying it 'errors' ?
Hi everyone.
I am stuck with this.
Plz help!!
Thanks in advance.
Regards.
--- On Thu, 3/12/09, manav dayal <manav_dayal85 at yahoo.co.in> wrote:
Subject: [mapguide-users] Connection Problem
Date: Thursday, 3 December, 2009, 6:08 PM
I have MGOS 2.0 installed on my machine and my sample application is running fine
on my machine using apache and tomcat.
When I try to access the same application from another machine by providing the
IP Address of the my machine in the url
it gives link broken type of errors.
http://ip/ gives a page which shows It works!
even
http://ip/mapguide/ shows the listing of the directories.
but when i try to access
http://ip/mapguide/javasamples/main.jsp
it gives errors but works on my machine.
can anyone help!!!
Thanks and Regards.
The INTERNET now has a personality. YOURS! See your Yahoo! Homepage.
-----Inline Attachment Follows-----
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
Zac Spitzer
+61 405 847 168
Zac Spitzer
+61 405 847 168
Zac Spitzer
+61 405 847 168
Zac Spitzer
+61 405 847 168
The INTERNET now has a personality. YOURS! See your Yahoo! Homepage. http://in.yahoo.com/
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091207/1b4bdf90/attachment.html
