[mapguide-users] Should I give up?
Neil_w nwilson at sec-landmgt.com
Mon Dec 7 16:20:38 EST 2009
I appreciate the encouragement but I have spent lots of time researching.
That is why I am getting discouraged. For all the time I have invested I
have made little progress. Without a step by step instuction guide for
creating maps it is more a trial and error process to get anywhere, with
long diversions to help forums seeking guidance when things don't wok.
I looked at the Mapguide guide for developers link you posted. Without
delving into it in detail it appears to be oriented to developing maps using
programming, which I am not able to do. I am limited to Maestro or some
other authoring software that does not require programming. That is why I
was interested in Fusion but I don't yet understand whether it would help me
author maps without programming. From one post it appeared that it could
load DWG files without converting them. If I have to go through a conversion
process to load a every DWG then Mapguide is probably not a good solution
for us and I won't want to put a lot of time into it. Again I need guidance
on this.
As I mentioned, I was able to connect to a couple of WMS services but I
could not figure out how to display any layers from them. Saving the
resource resulted in errors. I didn't know what they mean which lead to
another excursion to the forum. When I try to create a layer from the
connected WMS, there is no geometry for them available, so nothing displays.
We really could use a step by step guide for building maps, not just a
sample map with no guide on what the various components are. It took me a
while to figure out what the .ASP, .JSP. and .php layouts were. I had to
figure out on my own how to use a Flexible layout and add a query widget.
Again, no instruction whatsoever.
If anyone can direct me to some step by step guides or tutorials it might
get me back in the saddle.
View this message in context: http://n2.nabble.com/Should-I-give-up-tp4128103p4128554.html
