[mapguide-users] MGOS 2.0 to MGOS 2.1 (FINAL) upgradtion problem
balaji bitra bitbalaji at gmail.com
Tue Dec 8 00:03:54 EST 2009
hi
i am working on .net 2.0 framework (vs2005)  , backend as oracle 10g in
windows xp OS (IIS 5.0).My application runs fine in MGOS 2.0, due to
performance issue i changed  MGOS 2.1(FINAL), but the same application here
not working and it throws "OSGEO.Mapguide" namespace error in
Common.aspx(22line) in mapviewernet.
previously i post this error in the forum and there suggestions were also
implimented by me ,they are:
-> check the version of the .net framework either it is 2.0 or not
->check the bin folder either it contains the appropriate
dll's(mapguidedotnetapi.dll,....)
->check the application and folder security either may block by firewall or
access permissions,etc....
-> check for the previous uninstallation of MGOS 2.0 properly or not
i checked the all above conditions but no use, can any one have idea about
this problem.............
thanks in advance
balaji
View this message in context: http://n2.nabble.com/MGOS-2-0-to-MGOS-2-1-FINAL-upgradtion-problem-tp4130523p4130523.html
