[mapguide-users] Should I give up?
Mark Pendergraft
markp at Meadgilman.com
Tue Dec 8 12:07:43 EST 2009
I can't speak for your install, but I was able to connect to the WMS provider
you used in your screencast in Maestro ver. 1.0.9.15910 with MGOS 2.1. I
would uninstall the beta of Maestro and install the previous version and see
if that works.
-Mark P.
Neil_w wrote:
> I'm running Maestro 1.1.0.4358. I believe it is beta but it was highly
> touted by Jason Birch in one of his posts so I assumed it was stable.
> Should I go back to another version?
> The only other thing I can think of that might be causing problems is I
> downloaded an updated set of FDO providers from the Open Source website
> after installing Mapguide. I renamed the old FDO folder and added the
> updated folder to the Server folder.
> Perhaps all my troubles are due to a corrupt installation. That would
> certainly make life miserable for a new user.
> Can anyone verify whether I have a bad install or if it is the beta
> software?
> I have Map 2010 (Civil3D 2010).
View this message in context: http://n2.nabble.com/Should-I-give-up-tp4128103p4133772.html
