[mapguide-users] cannot read coordinate system from mysql database
Jackie Ng jumpinjackie at gmail.com
Tue Dec 8 23:34:52 EST 2009
Does your mysql database have a series of f_ database tables?
I believe the MySQL FDO provider requires these tables to exist, as these
tables store required FDO metadata needed by the provider. These tables
would exist if the MySQL data store was created via FDO. If these tables
don't exist the provider may not have the correct information regarding
things like coordinate systems, feature classes, etc.
- Jackie
thundercat wrote:
> I'm using ogr2ogr FW Toolkit to load and store spatial data (of ESRI type)
> into mysql. However when read the spatial data from mapguide studio, it
> cannot recognize the coordinate system of that  spatial data which is WGS
> 84 and recognize it as unknown. Therefore i overide it , and set the
> coordinate system as WGS 84. However, when previewing the map, it display
> an incorrect coordinate system. anyone can solve this ?. thanks
View this message in context: http://n2.nabble.com/cannot-read-coordinate-system-from-mysql-database-tp4036395p4137438.html
