[mapguide-users] Unhandled exception error. Maestro. Remote server
returned an error (559)..Help.
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Wed Dec 9 03:34:53 EST 2009
There was a bug in a previous version of Maestro, where moving a folder
into
itself twice would cause a corrupted respository.
Fortunately the problem only manifests itself if you call
EnumerateResources with a depth of -1,
and Maestro has been updated to not do that.
Try the newest preview version of Maestro and see if the problem goes away,
if so, your repo may still be damaged inside, but at least you can work
with it.
Regards, Kenneth Skovhede, GEOGRAF A/S
Trevor Wekel skrev:
> Hi Peter,
> You may be able to access the MapGuide repository using the HTTP test
> pages http://(machinename)/mapguide/mapagent/index.html
> <http://%28machinename%29/mapguide/mapagent/index.html>.
> Try using Resource... EnumerateResources... with various resource
> IDs. If this works, then you may be able to execute a MoveResource to
> move the resources around.
> Regards,
> Trevor
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of
> *badgerseatfrogs
> *Sent:* December 8, 2009 1:53 AM
> *To:* mapguide-users at lists.osgeo.org
> *Subject:* [mapguide-users] Unhandled exception error. Maestro. Remote
> server returned an error (559)..Help.
> Help! I accidentally moved a data source or layer or folder or
> something in Maestro and now Maestro crashes upon loading map (see
> error msg image). Can I recover what I've done? How can I debug? Can I
> access the XML's for the layers and maps (without Maestro)? New to
> Mapguide so have only modified Sheb. example and haven't de-bugged any
> applications as yet. P
> P at AFAP (The Australian Foundation for the Peoples of Asia and the
> Pacific).
> View this message in context: Unhandled exception error. Maestro.
> Remote server returned an error (559)..Help.
> <http://n2.nabble.com/Unhandled-exception-error-Maestro-Remote-server-returned-an-error-559-Help-tp4131265p4131265.html>
> Sent from the MapGuide Users mailing list archive
> <http://n2.nabble.com/MapGuide-Users-f1803227.html> at Nabble.com.
> mapguide-users mailing list
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091209/89c0057b/attachment.html
