[mapguide-users] Unhandled exception error. Maestro. Remote
server returned an error (559)..Help.
Trevor Wekel
trevor_wekel at otxsystems.com
Tue Dec 8 04:53:50 EST 2009
Hi Peter,
You may be able to access the MapGuide repository using the HTTP test pages http://(machinename)/mapguide/mapagent/index.html.
Try using Resource... EnumerateResources... with various resource IDs. If this works, then you may be able to execute a MoveResource to move the resources around.
Regards,
Trevor
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of badgerseatfrogs
Sent: December 8, 2009 1:53 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Unhandled exception error. Maestro. Remote server returned an error (559)..Help.
[http://n2.nabble.com/file/n4131265/maserror.bmp]Help! I accidentally moved a data source or layer or folder or something in Maestro and now Maestro crashes upon loading map (see error msg image). Can I recover what I've done? How can I debug? Can I access the XML's for the layers and maps (without Maestro)? New to Mapguide so have only modified Sheb. example and haven't de-bugged any applications as yet. P
P at AFAP (The Australian Foundation for the Peoples of Asia and the Pacific).
View this message in context: Unhandled exception error. Maestro. Remote server returned an error (559)..Help.<http://n2.nabble.com/Unhandled-exception-error-Maestro-Remote-server-returned-an-error-559-Help-tp4131265p4131265.html>
Sent from the MapGuide Users mailing list archive<http://n2.nabble.com/MapGuide-Users-f1803227.html> at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091208/ccadf390/attachment.html
