[mapguide-users] Raster problems with MGOS 2.1
isca mapguide2007 at gmail.com
Thu Dec 10 14:24:08 EST 2009
I have done some tests by adding the GDAL provider to the
DataConnectionPoolExcludedProviders list. At first glance it seems to be
much more stable now. Regarding performance I did not note any differences.
I will anyway create a new trouble report for it as the MapGuide server
crashes very fast when not making this configuration change.
isca wrote:
> Helllo Kenneth,
> I will certainly try this out but I don't know if I can use it for
> production. I guess it will bring down the performance of the vector
> layers also.
> Maybe I could try it out with adding the GDAL provider to the
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> Have you tried the trick Jason posted?
>> "I had to set DataConnectionPoolEnabled to 0 under the
>> FeatureServiceProperties section of serverconfig.ini to get my install
>> stable."
>> Regards, Kenneth Skovhede, GEOGRAF A/S
>> isca skrev:
>>> I have upgraded my MGOS 2.0.1 towards 2.1 and the improvement in speed
>>> is
>>> incredible. But the problem child of MGOS since the beginning seems
>>> still to
>>> exist -> rasters. When turning raster layers on/off in the viewer I get
>>> very
>>> fast an error indicating "can make no more connections to GDAL
>>> provider".
>>> Although the service doesn't crash anymore the web api seems to stuck.
>>> Is there a way to overcome this problem (increasing the number of
>>> allowed
>>> connections ?) ?
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Raster-problems-with-MGOS-2-1-tp4079477p4147275.html
