[mapguide-users] MGOS 2.1 - ECW
Trevor Wekel trevor_wekel at otxsystems.com
Thu Dec 10 18:46:18 EST 2009
Oops... The original message was regarding ECW imagery.  So I performed the same sequence of steps with a directory of ECW images and got the same result.
As a side note, it looks as though full color orthophoto ECW imagery seems to be about 2x faster than the same imagery in MrSID format when displayed under GDAL.  Many months ago, I also noticed the same ECW/MrSID behaviour when using the Autodesk Raster Provider.
Regards,
Trevor
Sent: December 10, 2009 4:31 PM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] MGOS 2.1 - ECW
Hi Kenneth,
I've been doing some testing of MrSID data with the MGOS 2.1 release and Maestro 1.1.0.4358.  My MrSID images have embedded correlation information.  When I try to save the feature source, Maestro throws the following error message "Spatial context extent appears to be invalid (or default)."  I save the resource despite the error.
Using the HTML test pages, the resource is correctly generated with the coordinate system override.
<FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
  <Provider>OSGeo.Gdal</Provider>
  <Parameter>
    <Name>DefaultRasterFileLocation</Name>
    <Value>%MG_DATA_PATH_ALIAS[casil]%7.5m/sid/</Value>
  </Parameter>
  <SupplementalSpatialContextInfo>
    <Name>Default</Name>
    <CoordinateSystem>PROJCS["UTM83-10",GEOGCS["LL83",DATUM["NAD83",SPHEROID["GRS1980",6378137.000,298.25722210]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["false_easting",500000.000],PARAMETER["false_northing",0.000],PARAMETER["central_meridian",-123.00000000000000],PARAMETER["scale_factor",0.9996],PARAMETER["latitude_of_origin",0.000],UNIT["Meter",1.00000000000000]]</CoordinateSystem>
  </SupplementalSpatialContextInfo>
</FeatureSource>
However, I notice there is no config document associated with the resource.  Does the GDAL provider use a configuration document?  If so, should Maestro be generating one?
Also, it looks as though the spatial contexts are not being returned correctly for my MrSID images.  The bounds on the GetSpatialContexts HTTP op are the bogus/default ones.  This is probably a defect we need to investigate.  The imagery does appear if the bounds of the map extents are set correctly but this could be a non-obvious problem to overcome for new users.
-<http://localhost:8008/mapguide/mapagent/mapagent.fcgi?OPERATION=GETSPATIALCONTEXTS&VERSION=1.0.0&LOCALE=en&CLIENTAGENT=MapGuide+Developer&RESOURCEID=Library%3A%2F%2FRaster%2Fcasil%2F7.5m_sid.FeatureSource&ACTIVEONLY=0&FORMAT=text%2Fxml> <<Extent>
-<http://localhost:8008/mapguide/mapagent/mapagent.fcgi?OPERATION=GETSPATIALCONTEXTS&VERSION=1.0.0&LOCALE=en&CLIENTAGENT=MapGuide+Developer&RESOURCEID=Library%3A%2F%2FRaster%2Fcasil%2F7.5m_sid.FeatureSource&ACTIVEONLY=0&FORMAT=text%2Fxml> <<LowerLeftCoordinate>
  <<X>-10000000</X>
  <<Y>-10000000</Y>
  </LowerLeftCoordinate>
-<http://localhost:8008/mapguide/mapagent/mapagent.fcgi?OPERATION=GETSPATIALCONTEXTS&VERSION=1.0.0&LOCALE=en&CLIENTAGENT=MapGuide+Developer&RESOURCEID=Library%3A%2F%2FRaster%2Fcasil%2F7.5m_sid.FeatureSource&ACTIVEONLY=0&FORMAT=text%2Fxml> <<UpperRightCoordinate>
  <<X>10000000</X>
  <<Y>10000000</Y>
  </UpperRightCoordinate>
  </Extent>
Thanks,
Trevor
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth Skovhede, GEOGRAF A/S
Sent: December 10, 2009 12:47 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] MGOS 2.1 - ECW
The GDAL provider is a little special, in that it never reports errors.
Instead it returns the default extent, as you have in your xml below.
Sometimes (perhaps an MG bug or a specific format issue?), the default extents are also
returned for perfectly valid data, making it impossible to detect errors :(.
The only way to see the data, is to set up a map with the correct coordinate system and
extents. Then add the layer and preview the map.
The GDALOPEN message you get means that the file was read correctly.
I'm not sure what aux or HFA has to do with ECW though.
IIRC (90% certain :)), it reports "succeeds as ECW" in my setup.
The "Value cannot be null" could be the indicator, but since you can get
the schema, I suspect that it is working anyway.
In Maestro (the latest preview), there is a bug with the coordinate system override,
you need to use the "advanced" editor, or the coordsys override is not set (there is an issue registered).
Regards, Kenneth Skovhede, GEOGRAF A/S
Denis Lalonde skrev:
I currently have several XP based laptops running MGOS 2.02 (IIS, PHP) and one server (MGOS 1.2, IIS, PHP). All of the maps on each were authored using Studio and each have a 1.05Gb ECW displaying correctly.
However, I can not seem to get the same ECW to run correctly with MGOS 2.1 on another new XP laptop (IIS, PHP).  I've tried using both Studio 2009 as well as Maestro to no avail.
With studio, I use the GDAL provider and connect to an external data source via a pre-configured alias (C:\Data\ECW_2007). I then select the ECW via the "data files" and then do a coordinate override. When I add the layer using this data source and preview it, nothing appears.
No errors show up in the log show up and running in debug mode shows no errors. I only get messages of type: "GDAL: GDALOPEN <C:\DATA\ECW_2007/Cornwall_10cm_20-1.aux, this=0146110> succeeds as HFA" (I think that means no errors...correct?).
I've never used Maestro before, but I think I do everything right there too. I select the GDAL Provider, of "type Single file or folder", point to my .ecw in the Aliased folder and override the Coordinate System to UTM83-18.
When I create a layer for this datasource however, I get this message:
"Failed to read schema from data source.
The operation gave the error message: Value cannot be null.
Parameter name:  input"
After that message shows up, I select "default: default" in the Schema drop down and "Image" automatically appears in the Raster drop down.
If I check the XML of the datasource, the extents shown don't make any sense.  This is apparent when I preview a map with the ECW because the map is centered at 0X, 0Y. Why is that? (See XML below)
I've tried repeating everything several times, without success. I really need this to work. What has changed that this doesn't work anymore?
If anyone wants to test drive the ECW, I can make it available for download. Let me know.
<?xml version="1.0"?>
<FdoSpatialContextList xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xsi:noNamespaceSchemaLocation="FdoSpatialContextList-1.0.0.xsd">
  <ProviderName>OSGeo.Gdal.3.4</ProviderName>
  <SpatialContext IsActive="true">
    <Description>System generated default FDO Spatial Context</Description>
    <CoordinateSystemName>Default</CoordinateSystemName>
    <CoordinateSystemWkt>LOCAL_CS["*XY-MT*",LOCAL_DATUM["*X-Y*",10000],UNIT["Meter", 1],AXIS["X",EAST],AXIS["Y",NORTH]]</CoordinateSystemWkt>
    <ExtentType>Static</ExtentType>
    <Extent>
        <X>-10000000</X>
        <Y>-10000000</Y>
        <X>10000000</X>
        <Y>10000000</Y>
    </Extent>
    <XYTolerance>0.001</XYTolerance>
    <ZTolerance>0.001</ZTolerance>
  </SpatialContext>
</FdoSpatialContextList>
mapguide-users mailing list
mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091210/29ef0471/attachment.html
