[mapguide-users] MGOS 2.1 - ECW
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Fri Dec 11 03:01:55 EST 2009
Hi Trevor.
The message reported by Maestro is a warning, because it can see that
the extents are invalid.
I think 2.0.2 returned the correct bounds, so perhaps a change after
that resulted in this problem.
IIRC, the coordinate system was also returned correctly in 2.0.2.
In 2.0.2 (and 2.1), the XY-M and default extents was returned by the
provider if you gave it an empty folder.
I would think it should throw an error because no files were loaded.
The config document is optional (afaik) but is created if you use a
composite set of ECW files.
Regards, Kenneth Skovhede, GEOGRAF A/S
Trevor Wekel skrev:
> Oops... The original message was regarding ECW imagery.  So I
> performed the same sequence of steps with a directory of ECW images
> and got the same result.
> As a side note, it looks as though full color orthophoto ECW imagery
> seems to be about 2x faster than the same imagery in MrSID format when
> displayed under GDAL.  Many months ago, I also noticed the same
> ECW/MrSID behaviour when using the Autodesk Raster Provider.
> Regards,
> Trevor
> *From:* Trevor Wekel
> *Sent:* December 10, 2009 4:31 PM
> *To:* 'MapGuide Users Mail List'
> *Subject:* RE: [mapguide-users] MGOS 2.1 - ECW
> Hi Kenneth,
> I've been doing some testing of MrSID data with the MGOS 2.1 release
> and Maestro 1.1.0.4358.  My MrSID images have embedded correlation
> information.  When I try to save the feature source, Maestro throws
> the following error message "Spatial context extent appears to be
> invalid (or default)."  I save the resource despite the error.
> Using the HTML test pages, the resource is correctly generated with
> the coordinate system override.
> <?xml version="1.0" encoding="UTF-8"?>
> <FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
>   <Provider>OSGeo.Gdal</Provider>
>   <Parameter>
>     <Name>DefaultRasterFileLocation</Name>
>     <Value>%MG_DATA_PATH_ALIAS[casil]%7.5m/sid/</Value>
>   </Parameter>
>   <SupplementalSpatialContextInfo>
>     <Name>Default</Name>
> <CoordinateSystem>PROJCS["UTM83-10",GEOGCS["LL83",DATUM["NAD83",SPHEROID["GRS1980",6378137.000,298.25722210]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["false_easting",500000.000],PARAMETER["false_northing",0.000],PARAMETER["central_meridian",-123.00000000000000],PARAMETER["scale_factor",0.9996],PARAMETER["latitude_of_origin",0.000],UNIT["Meter",1.00000000000000]]</CoordinateSystem>
>   </SupplementalSpatialContextInfo>
> </FeatureSource>
> However, I notice there is no config document associated with the
> resource.  Does the GDAL provider use a configuration document?  If
> so, should Maestro be generating one?
> Also, it looks as though the spatial contexts are not being returned
> correctly for my MrSID images.  The bounds on the GetSpatialContexts
> HTTP op are the bogus/default ones.  This is probably a defect we need
> to investigate.  The imagery does appear if the bounds of the map
> extents are set correctly but this could be a non-obvious problem to
> overcome for new users.
> <http://localhost:8008/mapguide/mapagent/mapagent.fcgi?OPERATION=GETSPATIALCONTEXTS&VERSION=1.0.0&LOCALE=en&CLIENTAGENT=MapGuide+Developer&RESOURCEID=Library%3A%2F%2FRaster%2Fcasil%2F7.5m_sid.FeatureSource&ACTIVEONLY=0&FORMAT=text%2Fxml>
> <<Extent>
> <<LowerLeftCoordinate>
> * * <<X>*-10000000*</X>
> * * <<Y>*-10000000*</Y>
> * * </LowerLeftCoordinate>
> <<UpperRightCoordinate>
> * * <<X>*10000000*</X>
> * * <<Y>*10000000*</Y>
> * * </UpperRightCoordinate>
> * * </Extent>
> Thanks,
> Trevor
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Kenneth
> *Sent:* December 10, 2009 12:47 AM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] MGOS 2.1 - ECW
> The GDAL provider is a little special, in that it never reports errors.
> Instead it returns the default extent, as you have in your xml below.
> Sometimes (perhaps an MG bug or a specific format issue?), the default
> extents are also
> returned for perfectly valid data, making it impossible to detect
> errors :(.
> The only way to see the data, is to set up a map with the correct
> coordinate system and
> extents. Then add the layer and preview the map.
> The GDALOPEN message you get means that the file was read correctly.
> I'm not sure what aux or HFA has to do with ECW though.
> IIRC (90% certain :)), it reports "succeeds as ECW" in my setup.
> The "Value cannot be null" could be the indicator, but since you can get
> the schema, I suspect that it is working anyway.
> In Maestro (the latest preview), there is a bug with the coordinate
> system override,
> you need to use the "advanced" editor, or the coordsys override is not
> set (there is an issue registered).
> Denis Lalonde skrev:
> I currently have several XP based laptops running MGOS 2.02 (IIS, PHP)
> and one server (MGOS 1.2, IIS, PHP). All of the maps on each were
> authored using Studio and each have a 1.05Gb ECW displaying correctly.
> However, I can not seem to get the same ECW to run correctly with MGOS
> 2.1 on another new XP laptop (IIS, PHP).  I've tried using both Studio
> 2009 as well as Maestro to no avail.
> With studio, I use the GDAL provider and connect to an external data
> source via a pre-configured alias (C:\Data\ECW_2007). I then select
> the ECW via the "data files" and then do a coordinate override. When I
> add the layer using this data source and preview it, nothing appears.
> No errors show up in the log show up and running in debug mode shows
> no errors. I only get messages of type: "GDAL: GDALOPEN
> <C:\DATA\ECW_2007/Cornwall_10cm_20-1.aux, this=0146110> succeeds as
> HFA" (I think that means no errors...correct?).
> I've never used Maestro before, but I think I do everything right
> there too. I select the GDAL Provider, of "type Single file or
> folder", point to my .ecw in the Aliased folder and override the
> Coordinate System to UTM83-18.
> When I create a layer for this datasource however, I get this message:
> /"Failed to read schema from data source./
> /The operation gave the error message: Value cannot be null./
> /Parameter name:  input"/
> After that message shows up, I select "default: default" in the Schema
> drop down and "Image" automatically appears in the Raster drop down.
> If I check the XML of the datasource, the extents shown don't make any
> sense.  This is apparent when I preview a map with the ECW because the
> map is centered at 0X, 0Y. Why is that? (See XML below)
> I've tried repeating everything several times, without success. I
> really need this to work. What has changed that this doesn't work anymore?
> If anyone wants to test drive the ECW, I can make it available for
> download. Let me know.
> /<?xml version="1.0"?>/
> /<FdoSpatialContextList
> xsi:noNamespaceSchemaLocation="FdoSpatialContextList-1.0.0.xsd">/
> /  <ProviderName>OSGeo.Gdal.3.4</ProviderName>/
> /  <SpatialContext IsActive="true">/
> /    <Name>Default</Name>/
> /    <Description>System generated default FDO Spatial
> Context</Description>/
> /    <CoordinateSystemName>Default</CoordinateSystemName>/
> <CoordinateSystemWkt>LOCAL_CS["*XY-MT*",LOCAL_DATUM["*X-Y*",10000],UNIT["Meter",
> 1],AXIS["X",EAST],AXIS["Y",NORTH]]</CoordinateSystemWkt>/
> /    <ExtentType>Static</ExtentType>/
> /    <Extent>/
> /      <LowerLeftCoordinate>/
> /        <X>-10000000</X>/
> /        <Y>-10000000</Y>/
> /      </LowerLeftCoordinate>/
> /      <UpperRightCoordinate>/
> /        //<X>10000000</X>/
> /        <Y>10000000</Y>/
> /      </UpperRightCoordinate>/
> /    </Extent>/
> /    <XYTolerance>0.001</XYTolerance>/
> /    //<ZTolerance>0.001</ZTolerance>/
> /  </SpatialContext>/
> /</FdoSpatialContextList>/
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091211/47e6a8cd/attachment.html
