[mapguide-users] MG 2.1 Beta and WMS / FDO Exception
braccos Stefano.Bracco at eurac.edu
Fri Dec 11 03:14:28 EST 2009
Hi Bernhard,
Yes, it was the problem. I found the solution on the FDO Manual.
Seems it is fixed, not clear why the VERSION=1.3.0 seems to have
problems. I was reading the code and seems it is not taking into account
the different XSDs related to different versions.
Anyway it did the job, and now I can see my Raster and WMS layers inside
MG 2.1, which was not working  correctly in previous release!
Thanks a lot.
Stefano
[mailto:ml-node+4148112-1559491579 at n2.nabble.com]
Sent: Thursday, 10 December, 2009 22:53
To: Bracco Stefano
Subject: Re: [mapguide-users] MG 2.1 Beta and WMS / FDO Exception
What happens if you include a version=1.1.1 parameter in the URL for the
connection in MapGuide Maestro?
For example:
http://www.geoserver.de/GeoOgcWms1.3/servlet/map?&VERSION=1.1.1
instead of:
Still the same error?
If yes, could you sent me the URL of your WMS Service?
PS:
We're using Mapguide Enterprise 2010 (german version) and had the same
problem (error message) after upgrating from MGE 2009 to MGE 2010 and
solved
this problem by adding the version parameter.
Bernhard
View message @
http://n2.nabble.com/MG-2-1-Beta-and-WMS-FDO-Exception-tp3650617p4148112
.html
To unsubscribe from MG 2.1 Beta and WMS / FDO Exception, click here
< (link removed)
jY29AZXVyYWMuZWR1fDM2NTA2MTd8LTQ0ODc1MzY5Ng==> .
View this message in context: http://n2.nabble.com/MG-2-1-Beta-and-WMS-FDO-Exception-tp3650617p4149943.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091211/78b631fb/attachment.html
