[mapguide-users] MGOS 2.1: Failure with dynamic coordination transformation
Jason Birch jason at jasonbirch.com
Fri Dec 11 16:30:19 EST 2009
Transforming between XY-M and a real CS is not technically possible; the
previous version must have been "guessing" that the XY-M dataset was in the
same projection as the other datasets.
My bet is the change from PROJ.4 to Mentor as the underlying CS library
makes this a bit stricter, requiring you to manually specify the CS for the
arbitrary data before attempting to transform it (or not).
Jason
2009/12/10 isca <mapguide2007 at gmail.com>
> Hello,
> I have upgraded my MGOS 2.0.1 towards 2.1 and encountered following
> problem:
> - I have a map which has the X-YM coordinate system
> - adding layers which refer to a featuresource with X-YM coordinate system
> works fine
> - adding layers with coordinate system Belgian Lambert 72 causes following
> error message:
>    Error: Failed to stylize layer: RPA
>        The coordinate system initialization failed.
>        Could not initialize the geodetic transformation.
> When overriding the coordinate system it works fine, but in previous
> versions transformation took place automatically. Is this a change in
> behavour or a problem with the transformation between the coordinate
> systems
> Thanks in advance.
> http://n2.nabble.com/MGOS-2-1-Failure-with-dynamic-coordination-transformation-tp4145048p4145048.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091211/a72cf26d/attachment.html
