[mapguide-users] Mr SID...Have I installed Correctly?
Trevor Wekel trevor_wekel at otxsystems.com
Fri Dec 18 12:45:56 EST 2009
Hi Scott,
I have started a Trac page for compiling information from the user community regarding the GDAL Provider for MapGuide 2.1.  The webpage is located at http://trac.osgeo.org/mapguide/wiki/MGOS21GdalProvider.  The page currently covers installation, configuration, and debugging.
The directory structure you have outlined below might be a little bit off.
Thanks,
Trevor
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Flipper
Sent: December 18, 2009 9:10 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Mr SID...Have I installed Correctly?
I am currently on Mapguide 2.1...
I followed  the Instructions in this thread
http://n2.nabble.com/ECWs-and-MG-2-1-td2978248.html#a2978703
http://n2.nabble.com/ECWs-and-MG-2-1-td2978248.html#a2978703 .
I put the "GDALPLUGINS" folder into the "C:\Program Files
(x86)\OSGeo\MapGuide\Server\bin\" Folder
I put the geotiff.dll, jpeg_osgeo.dll, libtiff.dll, zlib_osgeo.dll Files in
the "C:\Program Files (x86)\OSGeo\MapGuide\Server\fdo" folder
and
I put the lti_dsdk_cdll.dll and lti_dsdk_dll.dll Files into the "C:\Program
Files (x86)\OSGeo\MapGuide\Server\bin\" Folder
Is this all correct?
I put a coordinate system override on my datasource to match the SIDS
coordinate system which is The same as the Map...I didnt bother to preview
the layer since that never seemed to work on any release...I then put My
layer in my map...And The raster doesnt show up...The SDW file is good I
tested it in map...
Do i have to make a config file?
I see allot of posts but the one cited above seems to be the only one where
someone got this working...Is this a bug and I should stop trying or did I
put something in the wrong place?
View this message in context: http://n2.nabble.com/Mr-SID-Have-I-installed-Correctly-tp4187382p4187382.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
