[mapguide-users] Mr SID...Have I installed Correctly?
Flipper scotth at mpowerinnovations.com
Fri Dec 18 13:15:15 EST 2009
THANK YOu
[mailto:ml-node+4187884-1352066664 at n2.nabble.com]
Sent: Friday, December 18, 2009 11:48 AM
To: Flipper
Subject: RE: [mapguide-users] Mr SID...Have I installed Correctly?
Hi Scott,
I have started a Trac page for compiling information from the user community
regarding the GDAL Provider for MapGuide 2.1.  The webpage is located at
http://trac.osgeo.org/mapguide/wiki/MGOS21GdalProvider.  The page currently
covers installation, configuration, and debugging.
The directory structure you have outlined below might be a little bit off.
Thanks,
Trevor
-----Original Message-----
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4187884&i=0>
[mailto:[hidden email]
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4187884&i=1> ] On
Behalf Of Flipper
Sent: December 18, 2009 9:10 AM
To: [hidden email]
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4187884&i=2>
Subject: [mapguide-users] Mr SID...Have I installed Correctly?
I am currently on Mapguide 2.1...
I followed  the Instructions in this thread
http://n2.nabble.com/ECWs-and-MG-2-1-td2978248.html#a2978703
http://n2.nabble.com/ECWs-and-MG-2-1-td2978248.html#a2978703 .
I put the "GDALPLUGINS" folder into the "C:\Program Files
(x86)\OSGeo\MapGuide\Server\bin\" Folder
I put the geotiff.dll, jpeg_osgeo.dll, libtiff.dll, zlib_osgeo.dll Files in
the "C:\Program Files (x86)\OSGeo\MapGuide\Server\fdo" folder
and
I put the lti_dsdk_cdll.dll and lti_dsdk_dll.dll Files into the "C:\Program
Files (x86)\OSGeo\MapGuide\Server\bin\" Folder
Is this all correct?
I put a coordinate system override on my datasource to match the SIDS
coordinate system which is The same as the Map...I didnt bother to preview
the layer since that never seemed to work on any release...I then put My
layer in my map...And The raster doesnt show up...The SDW file is good I
tested it in map...
Do i have to make a config file?
I see allot of posts but the one cited above seems to be the only one where
someone got this working...Is this a bug and I should stop trying or did I
put something in the wrong place?
View this message in context:
http://n2.nabble.com/Mr-SID-Have-I-installed-Correctly-tp4187382p4187382.htm
l
mapguide-users mailing list
[hidden email]
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4187884&i=3>
http://lists.osgeo.org/mailman/listinfo/mapguide-users
[hidden email]
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4187884&i=4>
  _____
View message @
http://n2.nabble.com/Mr-SID-Have-I-installed-Correctly-tp4187382p4187884.htm
l
To unsubscribe from Mr SID...Have I installed Correctly?, click
< (link removed)
ubm92YXRpb25zLmNvbXw0MTg3MzgyfDI1OTExMDc5MA==>  here.
View this message in context: http://n2.nabble.com/Mr-SID-Have-I-installed-Correctly-tp4187382p4188038.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091218/5838fcb0/attachment.html
