[mapguide-users] Trouble getting started
Jonathan Rizzo jrizzo at Langan.com
Wed Dec 23 11:40:44 EST 2009
Hi Jason,
Thanks for the reply.  I did reboot after the installation.  This is a
32 bit OS.  I chose the IIS installation with .NET as the API.  The
mapguide logs are all empty except for Error.log.  It only has one entry
- "Success: Server started.".  I looked through the event viewer and
found one mention that the MapGuide service failed to start in a timely
fashion (A time out was reached - 30000 milliseconds).  So, I checked
and sure enough, the service was not started.  I started the service
manually, but I still get the same error when I try to log in.  I didn't
see any other errors.
Jon
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Wednesday, December 23, 2009 11:24 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Trouble getting started
Hi Jonathan,
Did you reboot after installation?
Is it a 32bit or 64bit server?
What web server and API choices did you make?
Are there any errors in the MapGuide or webserver logs?
Jason
2009/12/23 Jonathan Rizzo <jrizzo at langan.com>
I just installed MGOS 2.1 on Windows Server 2008, and I seem to be
having trouble.  It looks like it installed okay, but it won't let me
log in with the default Administrator password.  The login page comes
up, but when I try to log in, it says "Cannot establish connection".
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091223/8e263c20/attachment.html
