[mapguide-users] Trouble getting started
Scott hameister
scotth at mpowerinnovations.com
Wed Dec 23 11:48:44 EST 2009
I get that error when PHP hasn't installed correctly.Have you tried the web
server extensions to make sure they are working at least?
http://localhost/mapguide/mapagent/
Make sure Enumerate Resources gives you some XML output.if that is good your
FCGI is working.
I think there is a place Where you can set the Windows Environmental
variables so PHP loads correctly.
Check The newsgroup with a search.
Also check the handler mappings in IIS again a search in the User group
should reveal the mappings
On my install *.PHP mappings begin on the mapguide share to file C:\Program
Files (x86)\OSGeo\MapGuide\Web\Php\php5isapi.dll and are inherited
down..Make sure its local and doesn't say inherited there (bug of seen once)
Your FCGI handler should start at the mapagent subfolder and point to
C:\Program Files (x86)\OSGeo\MapGuide\Web\www\mapagent\isapi_MapAgent.dll
I'm not the expert here just happen to have IIS open and thought I'd chime
in.
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jonathan Rizzo
Sent: Wednesday, December 23, 2009 10:13 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Trouble getting started
Hello,
I just installed MGOS 2.1 on Windows Server 2008, and I seem to be having
trouble. It looks like it installed okay, but it won't let me log in with
the default Administrator password. The login page comes up, but when I try
to log in, it says "Cannot establish connection". The "Getting Started with
Version 2.0.x" guide basically just says "Install and Use", so I'm not sure
what's going on here. Any ideas? This is a new install on a brand new
virtual server.
Thanks,
Jon Rizzo
Langan Engineering & Environmental Services
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091223/a80c202c/attachment.html
