[mapguide-users] Points Disappearing with External SHP Connection
JC650
jmarvin at redwoodcity.org
Wed Dec 23 16:20:53 EST 2009
We are attempting to add some layers using a connection to a SHP folder.
Our Setup:
1) Mapguide 2010; Using the AJAX Viewer
2) Created an Aliased Folder on a Local Drive of the Server
3) Put 10+ SHP file Layers in the folder
4) Layer below has default theme (just changed color).
The Problem:
The point layer is very inconsistent. Sometimes the points will appear,
sometimes they will not. Simply panning or zooming in can cause the points
to disapear.
Here is a simple Screen Shot
Here is a Zoomed in view of a layer (red dots are the point layer):
http://n2.nabble.com/file/n4210614/GIS_Problem1.gif
Now look after I pan a small amount to the left. Notice there are fewer
dots (even though zoom level is the same and it is the same location on the
map).
http://n2.nabble.com/file/n4210614/GIS_Problem2.gif
The points will toggle on/off with no apparent pattern as I pan around.
Any ideas of why this is happening?
Thanks.
View this message in context: http://n2.nabble.com/Points-Disappearing-with-External-SHP-Connection-tp4210614p4210614.html
