[mapguide-users] Points Disappearing with External SHP Connection
Zac Spitzer zac.spitzer at gmail.com
Wed Dec 23 22:20:36 EST 2009
any chance you can create a MGP which demonstrates the problem?
z
2009/12/24 JC650 <jmarvin at redwoodcity.org>:
> We are attempting to add some layers using a connection to a SHP folder.
> Our Setup:
> 1) Mapguide 2010; Using the AJAX Viewer
> 2) Created an Aliased Folder on a Local Drive of the Server
> 3) Put 10+ SHP file Layers in the folder
> 4) Layer below has default theme (just changed color).
> The Problem:
> The point layer is very inconsistent.  Sometimes the points will appear,
> sometimes they will not. Simply panning or zooming in can cause the points
> to disapear.
> Here is a simple Screen Shot
> Here is a Zoomed in view of a layer (red dots are the point layer):
> http://n2.nabble.com/file/n4210614/GIS_Problem1.gif
> Now look after I pan a small amount to the left.  Notice there are fewer
> dots (even though zoom level is the same and it is the same location on the
> map).
> http://n2.nabble.com/file/n4210614/GIS_Problem2.gif
> The points will toggle on/off with no apparent pattern as I pan around.
> Any ideas of why this is happening?
> Thanks.
> View this message in context: http://n2.nabble.com/Points-Disappearing-with-External-SHP-Connection-tp4210614p4210614.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
