[mapguide-users] Points Disappearing with External SHP Connection
Denis Lalonde
denlalonde at gmail.com
Wed Dec 23 22:46:47 EST 2009
I think you'll find that deleting the troublesome layers' spatial index files
(.IDX) will take care of your problem. It worked for me.
I had the same issue a last week.
See my question on the FDO forum:
http://n2.nabble.com/Disappearing-Shape-File-Objects-td4113490.html#a4113490
JC650 wrote:
> We are attempting to add some layers using a connection to a SHP folder.
> Our Setup:
> 1) Mapguide 2010; Using the AJAX Viewer
> 2) Created an Aliased Folder on a Local Drive of the Server
> 3) Put 10+ SHP file Layers in the folder
> 4) Layer below has default theme (just changed color).
> The Problem:
> The point layer is very inconsistent. Sometimes the points will appear,
> sometimes they will not. Simply panning or zooming in can cause the points
> to disapear.
> Here is a simple Screen Shot
> Here is a Zoomed in view of a layer (red dots are the point layer):
> http://n2.nabble.com/file/n4210614/GIS_Problem1.gif
> Now look after I pan a small amount to the left. Notice there are fewer
> dots (even though zoom level is the same and it is the same location on
> the map).
> http://n2.nabble.com/file/n4210614/GIS_Problem2.gif
> The points will toggle on/off with no apparent pattern as I pan around.
> Any ideas of why this is happening?
> Thanks.
View this message in context: http://n2.nabble.com/Points-Disappearing-with-External-SHP-Connection-tp4210614p4211797.html
